02-28-2018, 12:49 AM | #1 |
Rep 32
Entire M3 subframe/diff swap
Hi everyone, been doing some research on the 135i and was curious if I were to source a complete M3 subframe with diff, suspension etc. such as this Minus the drive shaft which I understand needs to be customized or get a 1M drive shaft sourced but will all the other suspension bits be a direct bolt on to the 135i or do i need to customize the axles/arms or whatever to get it to install correctly into a 135i? Thanks in advance.
03-01-2018, 01:24 PM | #2 |
Rep 32
For those curious, after speaking with a few people minus the drive shaft it looks like it is a direct bolt on.
QUOTE=agl1911;22846560]Hi everyone, been doing some research on the 135i and was curious if I were to source a complete M3 subframe with diff, suspension etc. such as this Minus the drive shaft which I understand needs to be customized or get a 1M drive shaft sourced but will all the other suspension bits be a direct bolt on to the 135i or do i need to customize the axles/arms or whatever to get it to install correctly into a 135i? Thanks in advance.[/QUOTE] |
