02-25-2018, 09:11 AM | #1 |
///M SubDriver
1837
Rep 2,783
Drives: 2017 M3, 2020 X7 40i
ISTA-D Question - Controlling A Running Engine?
I have the ISTA-D (Reingold) program and have used it to support some maintenance items on both my F80 and also a bit on my wife's F25 (X3). I have used the software mostly for the maintenance procedures and clearing a few engine fault codes. However, I know that just scratches the surface of what this tool can do.
What I want to know is can I control a running engine with it, and if so how? By control, I am talking about running and holding the engine at a certain RPM for when I can't be in the driver seat with my foot on the gas. As the F-series cars are all "fly-by-wire" throttle control via the ECU, I would think this would be possible. Unfortunately, the ISTA-D program is not a very intuitive GUI. I did not want to go poking around the software without a little insight from those with some more experience with the software. Thanks!
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
02-25-2018, 12:54 PM | #2 |
Rep 3,945
Drives: 2015 M4 MG/SO
Yes, you may be able to, once connected to your car, explore ISTA by using text search or the service functions. If you don't find any ABL to do so, a rock or the old trick of wedging an object against the fuel pedal may work
If your reason for doing so may be part of a valid test procedure, then there are chances it may exist. |
02-25-2018, 01:29 PM | #3 | |
///M SubDriver
1837
Rep 2,783
02-25-2018, 01:44 PM | #4 |
Rep 3,945
After basic vehicle test is done, select DME, then next to "vehicle test", click on "Call Up ECU functions" and explore
