02-24-2018, 12:35 PM | #1 |
Rep 7,224
Any Ideas
Car started badly the other day. Yellow half engine light, rough idle, smelled of gas. Stalled, would not start again.
Checked for codes with Carly and this code popped up: 002BDA (rail pressure sensor, electrical: short circuit to ground). Fuel injector or HPFP? Wiring harness issue or high side fuel leak? This has happened 3 or 4 times in about a year. When I clear the code, the car behaves normal. Does anybody have any ideas?
02-24-2018, 02:24 PM | #3 |
Beachtown Bill Collector
582
Rep 1,062
Drives: 2012 135i
From the code you posted, it sounds like the fuel rail pressure sensor is experiencing an intermittent soft failure.
Esteban43787.00 |
02-24-2018, 02:44 PM | #4 |
Rep 334
Clearing the fault code won't solve the problem. Eventually the car won't run.
The smell of gas is usually caused by the injector remaining open. Also the plug gets fouled. For some reason, your injector starts functioning again. There is a part called the fuel rail pressure sensor which costs $50 and monitors the pressure of fuel pump. I'd try replacing it. You don't say which cylinder. If you know, I'd replace the plug or pull all of them for an examination. Finally, replace the injector on the offending cylinder. You'll have to take it to a shop to have it coded and make sure you record all the information about it, since it is necessary to code. |
Esteban43787.00 |
02-24-2018, 02:45 PM | #5 | |
Rep 7,224
Can you expand on that?
02-24-2018, 03:02 PM | #6 | |
Rep 7,224
BTW, I know clearing the code won't solve the problem, but it does allow me to drive the car if need be. lol
02-24-2018, 03:21 PM | #7 |
582
Rep 1,062
Drives: 2012 135i
The short circuit code that is logged for the fuel pressure sensor suggests that the sensor itself is either faulty or on the verge of failure. It's either giving implausible readings causing the injectors to likely remain open and introduce excess fuel into a combustion chamber that is not ready for it, or is experiencing an intermittent electrical failure which is sending a bad signal, causing the same issue.
Because the code came up for the sensor itself and not an injector, I'm inclined to posit that the failure is with the sensor. Nonetheless, it could also be an injector that is no longer up to spec, leaking fuel into the cylinder. Either way, it's good idea to see how fouled the plugs are. Eventually, continuing to drive with this issue can cause a clogged catalytic converter. The same problems can be caused by misfiring coil packs which also result in excess fuel going downstream. |
Esteban43787.00 |
02-24-2018, 04:09 PM | #8 | |
Rep 334
However, I have been fixing stuff like this for a while. I used to enjoy it, and today I find it a PITA. What I once did was study the problem and devise a theory to fit the problem. I then tried to solve it. Sometimes I actually did! Today I take a different approach. When I see words like electrical or short, I look for a bad ground or broken wire, very common stuff. I then replace parts starting with the cheapest one. High side, low side, who knows? The interactions between the ignition, fuel and computer just are too involved to fathom. Also the messages that a scanner can spit out sometimes aren't very revealing to the DIYer, but best suited to the trained pro. But I have found that the part that needs replacing or the repair necessary won't always make any sense in regard to the error message. In any case, it's worthwhile taking a shot at it. BTW, I recently diagnosed a bad injector on my own car with a new scanner I just bought. I had the Gold warranty, so the dealer fixed it. BMW was billed $500. I know how to make these kinds of repairs and could have done it for much much less. Why do I have the warranty? To handle the expensive stuff I can't fix like this DCT transmission. |
02-24-2018, 05:05 PM | #9 | |
582
Rep 1,062
Drives: 2012 135i
In terms of repairs, it's like you said: been there, done that with several other previous BMWs. The difference in the past was that I was relying on these cars for transportation and the stress level was always high. I still DIY most the maintenance on my Honda and E30, but those are a completely different story than the 135i in terms of cost of parts and complexity of the work. I let the warranty company pay my local independent mechanic who's also a good friend. By the way Esteban, if it's any consolation, I can detect a slight bit of misfiring in my 135i during hot idle. I'm nearly due for plugs as it is, so I'll know more when I have that completed. |
02-24-2018, 06:22 PM | #10 |
Rep 3,071
Sorry to see this buddy. I think you have some good advice above. I'd take it to a respectable indy and let them scan it with their BMW scan tools. Sounds like a bad sensor or injector.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
Esteban43787.00 |
02-24-2018, 06:28 PM | #11 |
Rep 7,224
Thanks Josh... got an appointment with my indy shop next Tuesday morning. Will report back here with what they find.
02-24-2018, 08:50 PM | #12 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Sorry to hear this. I am of no help. I have 35,000 miles at this point too.
Esteban43787.00 |
02-25-2018, 07:47 AM | #13 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
170k (10k of my own) miles, and no issues like this. (Insert NA FTW here)
Hope you find it's only an inexpensive issue!
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
Esteban43787.00 desertman1232213.50 |
02-25-2018, 08:12 AM | #14 |
Rep 6,196
That code seems pretty specific. DME saw 0 V from the high pressure sensor.
Most sensors operate from 0.5-4.5 V (on a 5V circuit). Below that means a short to ground somewhere (or internal failure of sensor, like a broken wire, but inside the sensor) above that means a short to power. (or internal short of sensor, so no resistance) I would think the first step would be to replace that sensor, and check the wiring going to it at the same time. |
Esteban43787.00 |
02-25-2018, 10:13 AM | #15 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Dealer contacted me on a new M2 available......ugh tempting....so is a new Raptor though lol.
02-25-2018, 10:43 AM | #16 |
BMW Cool Aide!
903
Rep 841
Wow, can't get more different.
02-25-2018, 10:52 AM | #17 | |
Rep 334
Multi-system Car Diagnostic Tool BMM V2.0
BTW, if you don't have a warranty, BMW charges you $150 to run a scan! I doubt the Indy gives you a free scan. Not to use cliches, but to be forewarned is to be forearmed. If you get the above scanner loaded with BMW software, it'll diagnose the problem. I know, because I just bought one, $150, and did just that. I had a Gold warranty, so the dealer fixed it charging BMW $500. Incidentally, I know how to replace an injector which is about as difficult as replacing a plug. BTW, if you don't have a warranty and can diagnose the problem, the dealer won't charge you for a scan. However, the point is to know just what the problem is, so some Homer doesn't rip you off. |
02-25-2018, 11:13 AM | #18 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
JimVonBaden902.50 |
02-25-2018, 11:48 AM | #19 |
3027
Rep 2,860
Get the Raptor *eats own words*, you've got the 'Vette for fun road-based stuff and doing impractical things. You just need a Raptor for the off-road stuff, and for doing practical things...
02-25-2018, 12:07 PM | #20 | ||
Rep 3,071
Indy shops can be good and bad. I'm always able to find a good one where I live and then I stick with it. With that code he should go to an Indy shop and ask them to replace the sensor and check the wires to it. Btw this error is intermittent for him so it comes and goes. Which to me indicates the sensor is going out. Why do I think that? I recently had a bad oil level sensor. It would intermittently show low oil. Changed sensor under warranty and fixed. Oh and any good shop won't charge to diagnose if you get the work done there.
02-25-2018, 12:41 PM | #21 |
Rep 7,224
Thanks bro... I don't think this is a turbo or DCT issue so it can probably happen to any of us.
chris_flies3027.00 |
02-25-2018, 03:14 PM | #22 | ||
582
Rep 1,062
Drives: 2012 135i
Esteban43787.00 |
