01-22-2018, 10:37 PM | #1 |
Rep 45
GTS MDM too little assistance?
Little help here guys.
Tonight I had the GTS coding done on my stage 1 F80. The wheel slip is crazy now. It's pretty much as if traction is completely off. Before tonight it was nearly perfect. The tune somehow made the traction control just right. Way less intrusive than stock. No power cut out and the perfect amount of wheel slip. 1) Am I just being a sissy and should I just re-learn to drive it? 2) Has anyone else felt like the GTS MDM was unsafe for the streets? UPDATE 2/11/18: I put on my big boy pants and relearned how to handle the car with GTS MDM. So far so good. Just don't get too ballsy with cold tires.
2015 F80 MG/Blk MDCT
Stage 1, M Perf. Elect. Steering Wheel, GTS Coding, KW Clubsports, Other goodies. Last edited by IbizaSandro; 02-11-2018 at 07:33 PM.. |
01-23-2018, 07:35 PM | #3 |
Rep 45
I'm realizing that to be the case. So then will I benefit from Euro MDM as a "middle" option? Whereas I leave traction ON under normal driving. Use Euro MDM in spirited driving. And full OFF on track.
Is that how you have yours set up?
Stage 1, M Perf. Elect. Steering Wheel, GTS Coding, KW Clubsports, Other goodies. |
01-23-2018, 07:39 PM | #4 |
Rep 8,364
I have only driven Euro MDM and not GTS.
01-23-2018, 08:10 PM | #6 | |
Rep 929
Drives: 2011 BMW 335i xDrive manual
IbizaSandro17.00 |
01-23-2018, 08:36 PM | #8 |
Rep 45
You're exactly right @Markus. I definitely need some better/wider tires to handle the extra power. I'll give Euro MDM a try and report back.
In the hands of the right driver the GTS MDM might be amazing. I just don't want to be testing my limits at freeway speeds.
M.a.r.k.u.s313.50 |
