01-11-2018, 04:46 AM | #1 |
Rep 356
Reviving an old topic as I'm new to StopTech and this appears to be an old issue. Hopefully those with experience can chime in. I swapped out the pads on the ST60 fronts and ST40 rears with Hawk DTC60. The fronts were easy and the old pads slid right out while the new ones slid right in. On the rear I encountered the dreaded slightly oversized (too tall) backing plate issue. The old pads would only come out with significant force (I looped zip ties on the holes in the backing plates and used these for leverage to slowly pull out the pads). The new pads likewise were difficult to put in and I used a rubber mallet to tap them in slowly. I did not do the initial install of the kit when the old pads (StopTech street performance pads) were put in, but my guess is they were hard to put in given my difficulty in their removal. I did one track day with the old pads and the brakes worked very well. The car seems to brake fine on the street with the new pads I just placed. Should I be concerned that the rear brakes will not function properly given the need to rubber mallet the pads into position or does anybody have experience with similar difficulty in pad placement but a functional system when used at track? Is it true that the pads may not move in toward the rotor properly if they were placed so tightly? I do see a transfer layer on the rear rotors from the new pads - not uniform but ringlike and similar to the front rotors which had NO pad swap issues. Thanks for any words of wisdom as I'm off to Thermal this weekend and would like some piece of mind.
01-11-2018, 11:11 AM | #2 |
Rep 564
First -- it would be nice to hit the "enter" buttons once or twice, it does help us readers!
Second -- Did you notice a lot of gunk/dirt/brake pad dust in the cavities of the ST-40? Might be worth an hour of your time, tops, to pull off the calipers and inspect/clean and retry installing them. From personal experience, on my ST-60/40 kit I didn't have any issues like you are reporting, front or back. But do recall once when I threw on a new set of pads, they were about 85-95% of the way seated in the caliper but that last 5-15% took some force to push. I took them back out, pull the guides/metal retainers and cleaned all around. Re-installed and boom! no issues after that. They do take a little wiggling back and forth sometimes however its always by hand. How thick is the coating on your backing plates? If cleaning out the caliper doesn't work, consider taking a file and lightly filing once end of the pads backing plate enough to get them to go in by hand. I only say that because you'll scrape off the finish on the caliper. |
Saandiaago92.50 |
01-11-2018, 08:16 PM | #3 |
Rep 356
Ha yes. More returns.
Thanks for the reply. I did not remove the caliper but did a quick brush to remove debris. I do think it was more of a fitment issue. Actually dropped the car off at a shop to let the experts handle it. Last night was brutal trying to get the pad swap done and I've now called "uncle". |
01-17-2018, 04:28 PM | #4 | |
Rep 564
2009 E90 M3 DCT IB Slick Top | 2017 911 Carrera White 7MT Slick Top | 2003.5 E46 M3 CB SMG | 2005 Audi A4 USP Black 6MT |
01-17-2018, 04:42 PM | #5 | |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
did it with the caliper on and just the caliper bridge removed
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
Saandiaago92.50 |
01-17-2018, 09:57 PM | #6 | ||
Rep 356
01-18-2018, 12:53 PM | #7 | |
Rep 564
01-18-2018, 09:12 PM | #8 | ||
Rep 356
