01-03-2018, 07:31 PM | #1 |
Rep 561
Exactly Why You Need To Warm Up Your Car When It's Cold
01-03-2018, 08:00 PM | #2 |
Rep 1,974
So it's a good idea to let it run a couple minutes before take off? I usually let it run 30 seconds then drive slowly afterwards. Seem to work pretty well.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
01-03-2018, 08:02 PM | #3 |
Stop the hate, get a V8
3851
Rep 8,625
Jesus Christ, this fucking article.
Warming up a car is literally one of the worst things you can do. How many goddamn times does this myth have to be brought back to life? Oh right, it's by Jalopnik.
Past: 2011.5 M3 sedan ZCP |
Flying Ace4984.50 SonnyJack326.00 EnVe461037.50 blue-mw217.00 6ixSpd6015.50 TimmyM56241.50 loveskiing967.50 Yoddha251.00 |
01-03-2018, 09:49 PM | #5 |
KPop
148
Rep 235
Since my M3 isn't a daily driver, I always start it up and wait until the cold-start high idle is finished before pulling it out of the garage. Regardless of the air temperature outside, I always drive it conservatively and shift under 3k RPM until I'm given the all clear by the variable redline and the oil temp gauge reads around 200 degrees. I'm not in any rush to get anywhere when I drive this car so I like taking my time. It's like a ritual, of sorts.
01-03-2018, 10:24 PM | #6 |
Apprentice
373
Rep 801
Why? Curious to know if letting your car warm up is really bad for a car...
01-04-2018, 02:23 AM | #8 |
Rep 644
Drives: 2018 6mt AW m2
01-04-2018, 02:56 AM | #9 |
Rep 257
You want to get a car up to temperature as quickly as possible so that the AFR leans out. When you first start the car cold it will run rich, and as the engine warms, it leans out. Running rich is not great for engines as it can lead to bore wash (where excess fuel, which is a great solvent, literally washes the cylinder bore of oil).
IMHO, modern engines need very little cold start idle - 30secs is typically plenty. Driving it gets the temps up quickly, leaning out the mixture, and gets to ideal AFR as quickly as possible. Thanks! S. |
01-04-2018, 09:12 AM | #10 |
Rep 801
Also, at idle, oil pressure is very low. Running the engine at moderate loads will get oil circulating better.
Net-net, there is no benefit to idling the car up to temperature. That said, there isn’t a lot of harm in it, either. I’ll freely admit that sometimes I warm cars up for my own comfort. But that’s for my comfort, not because it’s good for the car.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
KPop148.00 |
01-04-2018, 09:45 AM | #11 |
Rep 1,678
Drives: 2011 MCB E92 M3
I usually wait until the cold cycle finishes ~ 1 minute before backing out.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
01-04-2018, 10:14 AM | #12 | |
3851
Rep 8,625
Because engine load will warm the engine up, not idling. At idle there is basically zero load. All you are doing is trying to pump cold, thick oil through the engine. By sitting there for a few minutes, you're taking what could be just 10-15 seconds of cold start wear and stretching it out. The article alludes to this but then jumps all over the place on stupid tangents. It reads like an absolute mess. For the umpteenth time, this is how to drive a car in cold weather: 1. Start the car 2. Wait a few seconds 3. Drive away 4. Keep engine load low until the oil temperatures have risen If you are very concerned about cold start wear, and/or routinely drive your car in extremely cold temperatures, you can consider something like an engine block heater, oil pan warmer, Accusump, or some combination of the three.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 01-04-2018 at 10:22 AM.. |
01-04-2018, 10:24 AM | #13 |
F15 daddymobile
2350
Rep 3,510
01-04-2018, 10:37 AM | #14 | |
Rep 192
01-04-2018, 10:43 AM | #15 |
3851
Rep 8,625
Correct. The transmission and rear differential will take longer. They are also fairly thick fluids which is why things always seem clunky when it's cold.
94jedi830.00 |
01-04-2018, 11:13 AM | #16 |
Rep 5,483
I died several times this year already because I didn't warm my car up before leaving, with these cold temperatures you'll die a lot
gearboxes warm up via friction like most anything else in a car...letting them sit still without moving doesn't warm them up unless they have a cooling loop on a common heat exchanger with the engine. there's virtually no heat transfer from bell housing to the gearbox itself. That article is almost as awesomely bad as the HUGE NUM BER OF WARMING UP CARS THREADS WE HAVE ON HERE PLEASE DELETE THEM ALL KTHNXBYE
01-04-2018, 11:48 AM | #17 |
Rep 132
I usually just wait for the idle to come down to normal levels. I was in a huge rush the other day, drove off about 5 seconds after starting the engine. You could tell the car did not like it, it was very choppy and kept holding the high idle when I can to a stop about a 30 seconds later.
shimmy232350.00 |
01-04-2018, 12:30 PM | #18 |
Rep 1,198
Drives: 2021 F87 M2c. LBB, 6mt
Like most of the above, I want for the RPMs to chill and then slowly drive off until oil comes up to temp.
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
01-04-2018, 05:02 PM | #19 |
Rep 1,913
Drives: Here and There
My morning ritual:
1) Open door into the garage and push button on the wall to open the actual garage door. 2) Get in car. 3) Start car. 4) Put on seat belt. 5) Put car in 1st. 6) Go to work. From opening the garage to pulling it out of the garage is about 15 seconds. I shift around 3k - 3.25k until I'm up to temp. I generally get up to temp once I'm at the on-ramp for my highway commute. And then I let her rip! |
01-04-2018, 08:00 PM | #20 | |
Rep 256
By that time the engine oil is the right temp and there is no driving redline down time. |
01-04-2018, 08:03 PM | #21 | |
Rep 2,336
1) walk outside 2) get in car 3) put on seat belt 4) plug in aux to phone 5) windows down 6) start car 7) go wherever cause i dont have a job yet and i want one
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
