01-03-2018, 03:23 PM | #1 |
Rep 1,885
Coding issue - bimmercode app
Hi guys.
I've reproduced this error twice now - the first time I thought it was a mechanical issue and the dealer flashed all software back to stock. It fixed the problem. Basically using the bimmercode app, when I code auto side mirror close without delay using key fob or comfort access, my Driver and passenger windows start to open randomly to different degrees. When I reverse this the problem is fixed. It didn't occur when the car was previously coded with a cable. Just thought I would let people know. |
01-03-2018, 11:03 PM | #2 | |
Rep 8,364
drgmt984.50 |
01-03-2018, 11:05 PM | #3 | ||
Rep 1,885
01-03-2018, 11:22 PM | #5 | |
Rep 1,885
There is an option in bimmercode where you can set opening and closing delay to "no delay" I set closing delay to "no delay". I don't change parameters in expert coding mode. Happy to take your advice on what to Change |
01-03-2018, 11:44 PM | #7 | |
Rep 1,885
I think I might just set closing delay in isolation and see what happens. I may have changed both opening and closing delay which may have caused the problem. |
01-04-2018, 12:36 AM | #9 | |
Rep 8,364
FB = KeyFOB. PA = Comfort Access EDIT: KOMFORTOEFFNUNG & KOMFORTSCHLIESSUNG should be aktiv. You are looking for separate FDL's with "_" as above. Last edited by Almaretto; 01-04-2018 at 12:42 AM.. |
drgmt984.50 |
01-04-2018, 02:30 AM | #10 | ||
Rep 1,885
Almaretto2374.00 |
