12-30-2017, 08:25 PM | #2 |
Rep 44
You don’t need a puller. Undo negative battery cable. Just undo the injector hold down clamp. Disconnect electrical connector, disconnect fuel line. Reconnect fuel line to injector only and use that for leverage.
If you need more instruction look at newtis.info
2009 135i
https://bmw135iblog.wordpress.com |
12-30-2017, 10:24 PM | #4 |
Rep 278
I didn't have luck pulling by the fuel line. What worked for me is placing a 3/8" ratchet horizontally and using it as a stand from which to use a small pry bar (to pry up gently). Came out lickity split.
