12-26-2017, 11:27 AM | #1 |
Rep 122
DVD in motion after GTS CODING
Has anyone had an issue with coding DVD in motion after performing the GTS coding? I notices an HU_NBT2 appeared after performing the coding to GTS.
13 year BMW Master Tech. Consult for numerous auto shops. Owner of auto concierge service. Love to give car advice.
BMW OWNED: E90 sedan sport package (2 of them) F80 M3 F85 X5M |
12-27-2017, 12:54 AM | #3 |
Rep 122
What do you mean by ECU are separate?
12-27-2017, 03:49 AM | #4 |
Rep 8,364
12-28-2017, 01:58 PM | #5 |
Rep 122
Ahhh, so my assumption is when I load the FA, with the new GTS typschlussel change and go to code the car, should not switch to complete car coding, but leave it in construction mode and code the individual modules needed like DCT?
12-28-2017, 05:06 PM | #6 | |
Rep 8,364
Definitely stay away from coding entire vehicle, especially DME. |
12-28-2017, 05:23 PM | #7 |
Rep 122
So the attached instructions are incorrect?
12-28-2017, 11:03 PM | #8 |
Rep 8,364
12-29-2017, 01:07 AM | #9 |
Rep 122
Just for clarification, when you are changing a vehicle order, you're still coding not programming correct?
TT3 iN NyC247.00 |
12-29-2017, 01:57 AM | #10 | |
Rep 8,364
If you are using modified FA to change settings, it is VO coding. If you are using modified FA for TAL-Calculation/Processing, it is programming. |
