M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      12-21-2017, 10:24 AM   #1
Phil@BPC
Phil@BPC's Avatar
465
Drives: E39 M5/ E30 325is
2003 BMW M5  [0.00]
1990 BMW 325is  [0.00]
Bimmer Performance Center S63 tear down for bent rod (Pic Heavy)
Hey guys here are some photos I took during a tear down of an F10 that came in. Customer brought this M5 in because of a really bad sound coming from the engine. Surprisingly a check engine light never came on or a warning message. Once we brought it into our center we could hear the noise right away. Once we looked over the car and made sure everything externally was ok we performed a compression test. During this test we found cylinder 5 to be the culprit. We pulled the drivers side cylinder head and removed piston/ rod combination from cylinder 5. Hope this sheds light on something that's rarely seen.
Only very minor scoring on the cylinder walls. Most impressive is that the cylinder bore has a bend about half way facing the passenger side.
The culprit... still amazing this didn't set a check engine light or any malfunction warning messages.
      12-21-2017, 10:31 AM   #2
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1087
Drives: 2018 RS3, 991 Turbo
Nice breakdown... very common culprit. Too bad folks can prevent a lot of this by reading the plugs well beforehand. See the piston crown... so telling!
      12-21-2017, 11:03 AM   #3
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Originally Posted by Phil@BPC View Post
Hey guys here are some photos I took during a tear down of an F10 that came in. Hope this sheds light on something that's rarely seen.
Thanks for all the pictures. With the wrapped DPs I assume the motor had a tune of some sort?
      12-28-2017, 04:33 PM   #4
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
Correct this one did have a tune on it.
This S63 is going to be getting the BPC treatment. We will be building this motor. I will begin a new thread in a separate part of the forum. Ill tag this thread and the other together so they can be followed.
      12-29-2017, 10:14 AM   #5
DHUBM5
Drives: 2014 BMW M5
How can you safeguard against bent rods? Other than by not tuning your car cause that ship has sailed for me
2014 BMW M5 Comp Singapore Grey Metallic
Modifications: Gintani tune (91 and VP110 (724 rwhp)), MSR intakes, Akrapovic EVO exhaust, HRE S101, Evolve Catless Downpipes, Michelin PS4S, Vorsteiner Rear Diffuser, RW Carbon front lip and rear spoiler, M Perf Alcantara Steering Wheel, IND paint matched front and rear reflectors, Rayno nano carbon ceramic tint (40%), Hardwired Escort 9500ix
      12-30-2017, 07:28 AM   #6
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Great pics; thanks for sharing.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      01-01-2018, 04:04 PM   #7
allmotor_2000
1087
1. Tune for less torque down low (max at 650wtq sub-4K RPM)
2. Good gas... often rod will bend during a catastrophic event (pre-ignition)
Typically these rods are not bending because of the power levels, its more in the tuning and power profile
DHUBM529.50
      01-02-2018, 09:44 AM   #8
DHUBM5
Drives: 2014 BMW M5
Thanks for the info.
      01-20-2018, 11:46 PM   #9
3thirty5
3thirty5's Avatar
Drives: 2014 BMW M5
2014 BMW M5  [0.00]
Wow what a great post, fantastic photos!
Phil@BPC465.00
      01-24-2018, 08:17 AM   #10
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Great photo's, there is so much stuff on these engines.
Phil@BPC465.00
      01-24-2018, 09:31 AM   #11
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
Thanks!
Yes, there are quite a few harnesses and hoses on the engines.
      01-24-2018, 12:16 PM   #12
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
I enjoy threads like this, very informative. Thanks for posting!
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
Phil@BPC465.00
      01-24-2018, 05:59 PM   #13
josec70
josec70's Avatar
Great thread
m5post
