12-16-2017, 02:25 PM | #1 |
Rep 801
Rod Bearings / 13,900 Miles
Here are the first four. Kind of regretting not getting the BE Bolts. I had forgotten how tedious torque/release/torque/release/torque gets.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
12-16-2017, 02:46 PM | #2 |
Rep 450
12-16-2017, 03:30 PM | #5 |
Rep 801
Yep. BE Bearings going in. At least I'm doing this on an engine stand.
Also, FYI, the Gear Wrench 80588 set, which seems to be stocked at Advance Auto Parts, gives you the 6" torx sockets needed to pull the oil pan.
CSBM52722.50 thetastelingers4170.50 |
12-16-2017, 05:03 PM | #7 |
Rep 801
The remaining half.
Hardest part was getting the engine flipped back over. This thing is top heavy!
12-16-2017, 06:06 PM | #8 |
Rep 256
12-16-2017, 08:50 PM | #9 |
Rep 801
I’m prepping a 13.9k mile engine to go in next weekend. I’ll tear down the old engine once it’s out.
12-16-2017, 08:55 PM | #10 |
BimmerPost Supporting Vendor
3751
Rep 2,907
Drives: 2011 E93 M3
The point of the BE ARP bolts is to limit the bore distortion that can occur with the OEM bolts. It's not for ease of assembly- that's just a bonus. Excessive bore distortion plays a part in the premature wear of the bearings.
12-16-2017, 09:35 PM | #11 |
Retired Curmudgeon
2985
Rep 4,047
Those bearings look as bad as mine did at 2x the miles.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
K-M390.50 Flying Ace4984.50 |
12-17-2017, 09:02 AM | #12 |
BMW Veteran
310
Rep 503
Pretty amazing how bad they look given the mileage. Have you reliably confirmed the mileage on the engine somehow? Seeing these makes me think i should look at doing mine with 43K miles.
12-17-2017, 09:07 AM | #13 |
Rep 801
I saw the donor car (and actually pulled a few extra parts off) and have a carfax. The engine is also *extremely* clean.
///M Power-Belgium63406.00 |
12-17-2017, 10:21 AM | #14 |
Rep 4,014
Put them in an envelope with the documentation showing they are off of a 14,000 mile motor and mail them to BMW with a note inside that says "please open at the next shareholders meeting".
///M Power-Belgium63406.00 Ngilbe361618.50 L4ces337.00 Maxf80M3174.00 M_Three90.00 Flying Ace4984.50 94jedi830.00 |
12-17-2017, 11:39 AM | #15 | |
Rep 24,687
In 2013 BMW had to replace four 2013's . S65's with minus 15K miles on it and under BMW warranty ! One of the four was only a few months old and the owner had barely 6K miles on it ! Once the engine was replaced by BMW he dumped the car , and lost 40% value ...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
12-17-2017, 06:17 PM | #16 |
BMW Veteran
310
Rep 503
Well i can't say I'm not disappointed. I was honestly expecting minimal wear based on your description of the donor. Has anyone else pulled sub 30k mile bearings? If so, how did they look? That thread in the engine section is too long to navigate quickly.
12-17-2017, 09:37 PM | #17 | |
Rep 2,138
Drives: 2011 E92 M3
Still some wear but better. These are copper lead type.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
12-18-2017, 06:38 AM | #18 |
Rep 256
12-18-2017, 12:45 PM | #19 | |
BMW Veteran
310
Rep 503
so are we still to believe tolerance stack is the compounding cause for these wear patterns, along with less than ideal bearing clearance? Could it be that factory assembly of the connecting rods (i.e. torquing of the rod bolts, specifically) was done improperly on some cars? I mean tolerances are typically engineered to ensure that even under max stack one way or another, the end result is still acceptable. |
12-18-2017, 12:49 PM | #20 |
Rep 915
So did 99% of the purchasers.
Kiss French, Drive German, and Ride Italian....
spiderspider312.00 M_Three90.00 |
12-18-2017, 01:06 PM | #21 |
Rep 256
If you say so, the fact that so many appear as bad as they do leads me to think the fails are more than just a fluke.
