12-10-2017, 12:58 PM | #1 |
Rep 1,934
Coding retained following Takata Airbag Replacement at Dealer?
For those of you who have had the airbag replaced under the Takata recall at the dealer, have you retained both coding features and engine tuning? TIA.
12-10-2017, 03:03 PM | #5 |
Rep 4,014
12-10-2017, 03:12 PM | #6 |
Rep 4,107
Agreed with the above though I recall an earlier thread where there occasional failures of a module that required replacement. This would result in the loss of coding as I recall...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
12-10-2017, 05:13 PM | #7 |
Rep 979
No, they didnt touch the ecu during the airbag update.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
12-10-2017, 05:44 PM | #8 |
Rep 4,107
See the posts in this thread. On rare occasions the FRM module has blown. See post 769
http://www.m3post.com/forums/showthr...takata&page=35.
2021 X3 M40i
12-10-2017, 06:54 PM | #9 |
Rep 611
Drives: 2013 M3 coupe' 6mt
Did my airbag recall a month ago. My bpm Sport II tune and coding were unchanged.
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
12-10-2017, 07:11 PM | #10 |
Rep 4,014
Yes, my FRM module did blow on one of my cars. They did HAVE to reset my ECU which lost my DCT tune.
12-11-2017, 08:46 PM | #13 |
Driver
2692
Rep 2,714
I still don't understand this. What are they doing beyond unplugging/removing airbag A and replacing with airbag B?
E90M 6MT Slicktop Single Humper in need of a diet
6ixSpd6014.50 |
12-11-2017, 09:05 PM | #14 |
Save the manuals!
6015
Rep 6,746
Exactly. There is no coding involved here. A new airbag does not require any coding, unless the previous one was deployed. Even then, it's a simple clearing of the fault code and not modifying the modules in any way.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
12-11-2017, 09:20 PM | #15 |
Rep 4,014
Yep I understand. They also did my battery cable recall. From what I read, sometimes In doing the battery cable recall the FRM footwell module has been Known to blow. When it blew my windows were stuck down. The next day they had to install a new FRM module. They also had to reset the ECU. When they did I lost my DCT tune and coding.
12-11-2017, 09:36 PM | #16 | |
Rep 228
12-11-2017, 10:03 PM | #17 |
Rep 4,014
I corresponded with Alex@alpine when it happened. His response was "if the FRM footwell module is fried then they will have to replace it and they will have to reprogram your vehicle to factory specs. You will lose any tunes that are on the car". Which is what the SA told me at the time that it happened.
Edit: This happened during the battery cable recall. Not the airbag recall. |
12-12-2017, 02:09 PM | #18 |
Rep 5,483
They didn't even disconnect my battery. Took 20 minutes from when the car actually rolled in to when they told me it was ready, just replaced the whole assembly. You take a screwdriver, shove it in each side of the wheel, disconnect a connector, repeat. They probably ground themselves in some way before disconnecting. I figured they would disconnect the battery but nope
buddalun679.00 |
