12-07-2017, 07:47 PM | #1 |
Rep 3,727
Drives: 2018 M2
Annoying problem while fueling
So I have this irritating problem every time I go to the gas station while fueling it’s like the neck is too narrow and the fuel backs up making the pump stop. It used to only happen at certain gas stations but now it happens everywhere. As soon as I start the pump 5secs and it stops. It takes me 10min to fill the tank cuz I have to hold the trigger at the lowest flow and I constantly rust overfilling and spilling gas everywhere. I’ve tried holding the pump half way in, or with more pressure, angles it toward me or away and nothing works.
Anyone else have this problem or more importantly, a tip or fix? |
12-07-2017, 07:57 PM | #2 |
Rep 2,336
I'd have this happen at times also, I simply just stop filling and drive around a bit and go to a different gas station, but its happened to me at gas stations where I've completely filled up before
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
12-08-2017, 07:34 AM | #5 | |
Rep 3,727
Drives: 2018 M2
12-08-2017, 07:35 AM | #6 |
Rep 3,727
Drives: 2018 M2
12-08-2017, 07:37 AM | #7 |
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
I have had this problem, albeit very rarely. Typically the issue is with the pump itself, not the car.
12-08-2017, 07:40 AM | #8 |
BimmerPost Supporting Vendor
3751
Rep 2,907
Drives: 2011 E93 M3
There is a one way baffle/door at the base of the filler tube inside the tank. It's there to prevent gas theft and prevent slosh. It's on a hinge and I've seen that hinge get crusty which prevents the flap from opening all the way. That will cause the situation you're seeing.
12-08-2017, 08:05 AM | #9 |
Rep 4,014
12-08-2017, 10:06 AM | #10 |
Rep 423
I've had this exact problem but to a greater extent, I had to fuel it with 1-2 liters and take a break or the pump would stop. Turned out that the charcoal filter was clogged. Replacing it solved the issue immediately.
Part number 16 13 7 163 596 Only the US models have it and it's quite pricey for a shitty piece of plastic with activated carbon inside. It's located behind the left rear wheel. |
javarithms193.50 |
12-08-2017, 01:32 PM | #11 |
Chitty Chitty Bang Bang
146
Rep 230
I have this problem with my Land Rover and occasionally on the ///M. In my case the Rover is very picky on the angle you have the nozzle at and the ///M always looks like I have the nozzle in all the way but I end up having to really stuff that thing in there farther than I expected.
My guess is you know how to put gas in and you’re not a jackass like me. Perhaps there is a venting issue with tank causing the pump to shut down. (As mentioned above) Keep us posted. |
12-08-2017, 08:02 PM | #12 | |
Rep 3,727
Drives: 2018 M2
12-09-2017, 06:23 AM | #13 |
3751
Rep 2,907
Drives: 2011 E93 M3
12-09-2017, 06:45 AM | #14 |
Rep 423
I would suggest to inspect the charcoal filter. Much easier as you only need to remove the left wheel and the wheel well. Once you take it out you simply need to blow to each hole and check if there is no obstruction in any of them (the air needs to pass between all of them).
I had my whole fuel tank with hoses taken apart just to realize I needed to replace this filter, so I would suggest starting there |
12-09-2017, 08:42 AM | #15 |
3751
Rep 2,907
Drives: 2011 E93 M3
Yes. Seevin's suggestion is quite possible and much easier to assess.
12-09-2017, 10:43 AM | #16 |
Rep 272
12-09-2017, 03:52 PM | #17 | |
Rep 3,727
Drives: 2018 M2
12-10-2017, 03:24 PM | #19 |
Rep 11,891
My issue is then opposite. I usually have a problem pulling out
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
12-10-2017, 03:36 PM | #20 |
Rep 3,727
Drives: 2018 M2
12-10-2017, 04:56 PM | #21 |
Rep 368
Only happens at certain pumps, attendant told me it happens w a lot of newer BMWs.
Whenever it does happen though they just insert the nozzle upside down, and it doesn't lock up early |
