11-20-2017, 11:25 PM | #1 |
Rep 769
Weird noise coming from the front part of the engine
Hello everyone!
Just wanted to see if anyone here have had the problem where the engine is producing some type of "Whaaa" sound at idle and increases as rpm increase. This cannot be heard inside of the car but can be spotted very well from outside. My initial guess it's a pulley related but would like to confirm from sound experts The car runs fine, here is a link for a Dropbox video https://www.dropbox.com/s/u0gx7f7wwr...%20PM.mov?dl=0 Thank you very much |
11-21-2017, 08:46 AM | #2 | |
Rep 24,680
You have a vibration noise . Something is vibrating against something.. Be patient and open your ears , I'm pretty sure you can find the location of the noise . BTW...Your oil cap is leaking some oil.
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
11-21-2017, 10:35 PM | #3 | ||
Rep 769
Thank you |
///M Power-Belgium63392.50 |
11-22-2017, 09:17 AM | #4 |
Rep 769
Well yours is super obvious. I checked my fluid level and looks like it's slightly below the line but can't really tell lol. I think I will start off by flushing the fluid completely and replacing the reservoir. See if that will do it.
12-01-2017, 10:19 AM | #5 |
Rep 769
Update: Flushed the power steering fluid today and filled it to correct level. Noise is still there. Went to BMW and they said it's either tensioner pulley or power steering pump it self. Recommended to replace both just in case. 1500 for pump and 1200 for tensioner. They also said that the belt is slowly starting to spin off so I need to replace the tensioner and belts to prevent the belt from spinning off. They also said they are pretty positive it's just the tensioner. Anyone ever replaced their tensioner? From what I understand there are 2 tensioners right?
12-01-2017, 05:49 PM | #7 |
Rep 769
12-01-2017, 05:50 PM | #8 |
Rep 769
12-01-2017, 05:53 PM | #9 |
Rep 153
Ever since I bought the car two months ago, sound hasn't changed at all since then. But I took it to a very reputable shop who pointed to the power steering pump. I don't have any steering issues at all either
2009 E92 M3
2015 435i (previous) 2015 428i (previous) 2008 350z (previous) |
12-01-2017, 06:05 PM | #10 |
Rep 769
So, should we replace the pump? Is that what you saying? Looks like I need the tensioner anyway because I can push down on the belt and it dips. I will probably put Macht Schnell pulleys while I'm in there and see if that will help because power steering pump will be rotating slower
12-02-2017, 03:16 AM | #11 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
I vote power steering pump. Definitely an accessory on the belt system. I would check...
-PS Fluid level. -Idler tensioner for good tension to keep belt tight. -inspect PS pump, Alternator, and overall belt system.
12-02-2017, 03:07 PM | #12 | |
Rep 769
I am going to order the belt tensioner, idler pulley and Power Steering pulley plus new belts and will post an update some time later next week. Is there a DIY on tensioner pulley? Also, do you know what is hydraulic tensioner and how is it different from tensioner pulley? |
12-03-2017, 02:50 AM | #13 | ||
Lord Scrip
1815
Rep 3,013
Three Pedal Steve874.50 |
12-03-2017, 06:38 PM | #14 |
Rep 769
I am talking about these parts (link attached below). I cant really understand the difference. So i can purchase the hydraulic tensioner (First link) and it would substitute the belt tensioner pulley? (second link).
I am leaning towards just ordering a Standard belt tensioner pulley (2nd link), power steering pulley, idler pulley and may be turner motorsport crank pulley plus 2 belts. I like the fact that their product only has crank pulley of lower size rather than crank and a power steering reduced in size. (My car is daily driver) https://www.turnermotorsport.com/p-2...uine-bmw-part/ https://www.turnermotorsport.com/p-2...uine-bmw-part/ |
12-03-2017, 10:23 PM | #15 | |||
Rep 769
12-04-2017, 10:40 AM | #16 |
Rep 769
Update:
Ordered pulley service kit for 570$. Will install it later this week. Let's see if that will solve the problem? Does anyone know a DIY for Hydraulic tensioner replacement? |
12-04-2017, 11:02 AM | #17 |
Rep 611
Drives: 2013 M3 coupe' 6mt
What is the mileage on the car?
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
12-04-2017, 05:38 PM | #19 |
Lord Scrip
1815
Rep 3,013
Me either but I did it preemptively because it is an easy service and well worth it. The belt system is already parasitic to engine power, so keeping the pulley and belt system smooth ultimately helps the motor. Some environments speed up the wear, like in SoCal and heat effects belts by drying them out.
12-04-2017, 08:16 PM | #21 |
Rep 769
The tick tick tick sound is normal. I'm guessing the car is cold. Let it warm up and record again. I kind of heard something behind the tick tick tick sound but it should go away as your car warms up. Should take around a minute for it to go away depending on how long the car was not used and how cold it is
12-04-2017, 08:25 PM | #22 | |
Rep 2,336
