EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      11-19-2017, 10:33 AM   #1
jimmydick
Boner
jimmydick's Avatar
Drives: 18 AW ZCP
Springs changeout, ICM Calibration?
18' ZCP with a set of Eibach Pro springs on the way. I read in a few posts in multiple threads to calibrate ICM after installing springs. I searched for about 2 hours for information on how to execute this(assuming ISTA?). There does not appear to be a through explanation to this process on the forum. The Eibach thread only contains bits and pieces.
I also read in some threads the EDC needs calibrated. Would greatly appreciate elaboration, clarity and direction.
      11-20-2017, 10:38 AM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
EDC has a startup procedure to calibrate. It should come up after scanning vehicle. If not, you can search for EDC startup and run ABL.
      11-20-2017, 11:47 PM   #3
jimmydick
Boner
jimmydick's Avatar
Drives: 18 AW ZCP
ISTA?
      11-21-2017, 06:17 AM   #4
dheanswer
Drives: AY F82
Originally Posted by jimmydick View Post
ISTA?
Yep. Just did this last night through ISTA.
      11-21-2017, 10:26 AM   #5
jimmydick
Boner
jimmydick's Avatar
Drives: 18 AW ZCP
Thanks!
      11-21-2017, 12:18 PM   #6
Almaretto
Almaretto's Avatar
2374
ISTA?
Yes. ISTA+ (AKA Rheingold or ISTA-D).
      01-19-2018, 01:56 PM   #7
prodigymb
Drives: V10+ R8, 997TT, Plaid, G550
can this be done with ESYS or just ISTA
domino_z1248.50
      07-21-2019, 01:30 PM   #8
M4UFO
M4UFO's Avatar
Drives: 2019 M4 Comp
2019 BMW M4  [0.00]
Can this be done by the dealer only or by the company who installed the springs.
      07-21-2019, 01:32 PM   #9
jimmydick
Boner
jimmydick's Avatar
Drives: 18 AW ZCP
Originally Posted by M4UFO View Post
Can this be done by the dealer only or by the company who installed springs.
You can do it yourself with Reingold, which is available here on the forums. It took me 10 min to figure it out even though the program is not intuitive.
      10-13-2020, 12:54 PM   #10
Dtwok335
Germany
16
Drives: M3F80-Frozenblack-metallic
Hey I just coded the edc cs software. But I'm not able to delete the failure with ista. It errors out and tells me I have to clear error codes first. But if I clear the codes they stay and are not able to delete it.
f80post
