11-17-2017, 06:11 PM | #1 |
Rep 49
E92 muffler rear hanger deleted?
Was under the car the other day and noticed that the rear most hanger connections that are on the end of the muffler between the tips that bolts up under the grill in the bumper is mia. Doesn't look like it was removed or broke off. Looks like it was never welded on from the factory. Weird thing is the part that bolts to the body is there and there is only one orange rubber hanger on the one side, other side has none. Really weird, any ideas? Definitely didn't break off as i said cause there is no evidence of them ever even being welded to the back of the muffler flange. Was thinking maybe it had an aftermarket muffler at one time and the guy put a stock one back on from maybe an E90 or 93, do they not have them?
11-18-2017, 07:03 AM | #4 |
BimmerPost Supporting Vendor
3751
Rep 2,907
Drives: 2011 E93 M3
They all have them. Sedans, Verts, Coupes. The way they're welded onto the rear seam is pretty weak and susceptible to cracking and breaking off. When they do there's not usually an obvious sign of any broken welds since the casing material is so thin around the seam..
HerbNRacer145.50 |
11-22-2017, 04:34 AM | #5 | |
Rep 1,029
http://www.m3post.com/forums/showthr...hlight=trooper
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
