11-02-2017, 02:36 PM | #1 |
BimmerPost Supporting Vendor
9587
Rep 10,878
iND Red Start/Stop button DIY
Tools Required:
-Pry tool -Masking Tape -Tweezers or two small flat heads to release button tabs 1. Add a small piece of tape on the dash so that you don't leave any unwanted marks 2. Enter flat pry tool on the bottom corner section of the switch. 3.Release the clips and use your other hand to remove the switch from the dash. 4. With both hands you can now remove the switch 5. Next you will need to unplug the switch. Compress the plastic tab on the harness release 6. Next step is to remove the back cover of the switch. There is a series of plastic tabs that you need to release. 7. Once the tabs are released remove the back cover of the switch. 8. Photo showing the back cover off of the switch. 9. This is the only part I got stuck on for a moment You need to make sure that both tabs are compressed at the same time otherwise the button will not release. Please see the red arrows in this photo 10. After the tabs are released the button will slide out of the switch cover. 11. Time to install the Red button 12. Once the new button is in place install the back cover back onto the switch 13. Connect the wire back into the switch. 14. Press the switch back into place and Enjoy! Link to iND Red Start/Stop Button: https://ind-distribution.com/product?sku=IND-SSRB-F8X
Aaaaaaaaa7559.00 Yellowflash21369.50 Bosozoku693.50 CharlieVictor29.50 BatCam1.50 Rxpert186.50 Lukas Papwick15.00 soulcrft161.50 |
11-02-2017, 02:44 PM | #2 |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
stupid question, but im assuming it lights up like the original black one does?
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
11-02-2017, 02:48 PM | #3 |
9587
Rep 10,878
Yes, it does light up just like the factory one.
CharlieVictor29.50 |
11-02-2017, 02:56 PM | #4 |
Rep 4,393
sweeeeet. i like juicy red buttons. may have to get this simple mod. its always the little stuff.
11-02-2017, 03:17 PM | #8 |
9587
Rep 10,878
11-02-2017, 03:34 PM | #11 | |
Rep 3,945
Drives: 2015 M4 MG/SO
11-02-2017, 03:40 PM | #12 |
Rep 4,393
i looks like regular blue painter's tape. the strobe from the camera gives it some extra texture.
11-02-2017, 03:44 PM | #13 |
Rep 3,945
very possible! from little experience with car trim, blue or other painter's tape is useless depending on the car interior surface being pried against so I thought this to be a more "special" tape.
11-02-2017, 03:48 PM | #14 | |
9587
Rep 10,878
Quick video of the button when it lights up.
CharlieVictor29.50 BatCam1.50 |
11-02-2017, 03:49 PM | #15 | |
Rep 4,393
unless, like you said, it's a special interior trim protector tape that iND sources from Japan... like a special woven unicorn hair fiber mixed with an proprietary space age polymer because THAT'S HOW iND DO.
aboulfad1592.50 hatepotholez292.50 |
11-02-2017, 03:53 PM | #16 |
Rep 3,945
: unicorn hair fiber! I also apply few layers to no avail.
11-02-2017, 03:57 PM | #17 |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
i kind of love this. please make some for e9x/e8x
sterile stork373.00 |
11-03-2017, 01:21 PM | #21 |
Rep 1,055
