11-01-2017, 11:59 AM | #1 |
Rep 509
Coding F83 - EDC & Diff. Errors
HELP!
I've got a 2017 M4 6Sp. M.T. - Competition Package - Convertible. Has anyone coded the GHAS ("CS-EDC") and/or Differential ("GTS") on the Convertible? I keep getting two - three consistent errors: _* Chassis _* Chassis Stabilization _* Rear Differential (-> May be a False/Positive) I'm thinking maybe, being an F83, the Suspension & Diff. may be different?!? Any Input would be greatly appreciated! Cheers! |
11-01-2017, 02:30 PM | #2 |
Rep 3,945
Drives: 2015 M4 MG/SO
You need to get ISTA, run basic vehicle test and check the faults, then follow the measures plan.
11-01-2017, 02:53 PM | #3 |
Rep 509
11-01-2017, 02:57 PM | #4 |
Rep 3,945
Post a screenshot of the ISTA Faults, i recently helped someone offline w an F83, and the faults showed he needed to run VDC startup procedure.
As I mentioned above, you need to follow the measures plan, not just erase blindly faults in ISTA. |
Dr. Who302.50 |
