10-18-2017, 03:50 PM | #1 |
Roll Tide
285
Rep 579
BimmerCode basic & advanced coding
I know that I’m not using the standard coding software. Let’s skip that part for now. I wanted to review this and see what it’s limits were.
So far I have coded most of the things that we all want done. Seat belt warning screen and gongs removed, comfort access from key fob, video from usb, DVD in motion, ASD off etc... You can download a copy to your phone/tablet and look at a demo mode to see how much is there. It does change some when you connect to the car. I’m not very good (brave) in advanced mode but there are some advanced settings that work if you know where to go. Example, you can go from ID5 to ID6 Light. I’d greatly appreciate some help coding or locating the following: > Increased high beam intensity (LED) > No Dazzle headlamps > Eliminate speed lock for Bluetooth pairing and owners manual > Enable enhanced Bluetooth Thank you for your time & assistance.
AW/SO - ED delivery 6/20/16
PCD - 9/1/16 |
10-19-2017, 08:11 PM | #2 |
///M SubDriver
1837
Rep 2,783
Drives: 2017 M3, 2020 X7 40i
There are several coding threads, cheat sheets and tutorials for different options that can be coded on the F8X platform in the forums (see the coding sticky above). In these threads and cheat sheets, they have the various ECUs and parameters that must be changed. Once you know the ECU and parameters that need to be changed, you can use Expert Mode in BimmerCode to make the changes to code your car.
I have coded using both my laptop and iPhone using expert mode. Expert Mode with BimerCode is quite easy once you understand the basics of coding.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
10-24-2017, 01:35 PM | #3 | |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
01-21-2018, 08:40 PM | #4 |
You got my money?
3156
Rep 4,646
Bump
Can I disable the front PDC sensors in a 2017 m3 using this app in basic mode?
07-18-2023, 10:07 AM | #5 | |
Rep 27
I believe the code in BimmerCode would be... ACSM_3000_SBR_BF_GWF_SBR_BF for Passenger seat belt (active is ON. not active would turn it off). I just re-read your question and I misunderstood. Sorry, you wanted the parking sensors off. I couldn't find a cheat sheet code for that. Sorry |
07-18-2023, 05:08 PM | #6 | |
You got my money?
3156
Rep 4,646
Better late than never though!
