10-14-2017, 03:06 AM | #1 |
Rep 241
ZCP - CS or GTS code?
ok calling all people who’ve had coding done.
I am getting a zcp which I understand has different coding to the regular m3, but doesn’t this match the different springs and hardware? Do you really get all the zcp benefits by coding or is the hardware like springs actually different? Is the diff and steering physically different or is it just the coding? So my understanding is you can code GTS steering GTS DCT GTS ESP - not really sure what this does GTS diff - not really sure about this either - is there anything else I’m missing? - what are the CS options and how do they differ? - also which settings are related to different hardware on the models? - what’s people’s thoughts on CS vs GTS - opinions on optimum setup If you could elaborate on why you like a certain option it’d be great. |
10-14-2017, 05:59 AM | #2 |
Rep 20,741
Drives: 2021 911 turbo
One thing the CS has that the GTS does not is a revised calibration of the EDC (GTS has manualy adjustable full coilovers).
Further, according to AM&S supertest article, they say the CS ABS system has been greatly improved over the GTS to better take advatage of the r-compound tires.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
mrgold0.00 |
10-14-2017, 06:24 AM | #3 |
Rep 241
So this is what I’m talking about, settings that are specific to particular differences. So does that mean if you’ve got the zcp it’s best to stick to that specific EDC
10-14-2017, 10:12 AM | #5 |
Rep 20,741
It's all about different setups and compromises. The CP and CS EDC settings are optimized around their stock configuration. From what I gather, both cars have the same spring and sway-bar rates, the EDC calibration on the CS is probably more focused for a sportier drive with rather sticky tires. If you plan on upgrading the tires on your CP or plan to track regularly, it is probably worthwhile to upgrade to the CS EDC, DSC and ABS settings.
10-16-2017, 05:19 AM | #6 |
Rep 241
I’d like to hear from people who have had these changes made to get some real world examples
At this point I think I’ve had it confirmed there’s no difference between diff, eps, and traction for cs/gts. Tyres are one difference but not to worries about that. Interested in zcp damping and ca damping |
10-17-2017, 08:18 PM | #7 |
Rep 3,726
Just got everything done today on my f80 zhp. Gts power steering, gts dct, gts mdm, gts diff. Should have came from the factory this way. I left edc alone since my coder said there is very little difference between zhp edc and cs edc. I opted out as a result.
10-17-2017, 08:30 PM | #8 |
Rep 241
ok so can you throw me a bone and describe the difference over the stock setup? I'm interested to hear you explain it a bit in depth if you can. Does the steering weight just feel better for example or do you get more road feel?
10-17-2017, 08:47 PM | #9 |
Rep 3,726
At my computer now so I can type a detailed response.
GTS DCT - An absolute must. It transforms the DCT gearbox to the point where it feels like an entirely different vehicle. I was seriously considering ditching the F80 because the gearbox was driving me crazy. Everyone says "you need to learn to adapt to it, you are driving it wrong, etc." NOPE. The stock DCT software just sucks. Jerky acceleration is gone. Jerky downshifts is gone. Faster upshifts and non-jerky downshifts are in place. Going into reverse is instant. Slow speed driving (e.g., around parking lots) is MUCH better. You lightly press the throttle and it moves forward slowly and smoothly with no jerk. Stock, it was press throttle, go nowhere, press more throttle, you jerk forward, press more throttle, you hit the car in front of you. No more of that non-sense. It is transformational. Just do it, now. GTS Power Steering - 2nd best change relative to the DCT. When your steering wheel is dead center, when you move left or right, there is a "dead spot" that no matter how much you move it, the car stays straight. This means you need to give more steering input to get the car to turn. NO MORE!! With the GTS PS, you barely touch the steering wheel, it turns. The steering is more sensitive, but in a good, confidence inspiring way. For some reason, I also get the sensation that the steering is "smoother" in comfort mode. It's lighter, feels more natural, and makes the car a pleasure to drive on short or long journeys. You don't need to wrestle with the steering wheel as much. I can turn the wheel with my pinky finger and its super smooth. Definitely helps with driving fatigue in day to day traffic. The steering is noticeably more precise. Do it, now. GTS MDM - MDM hardly kicks in anymore. Makes the car feel more natural and balanced without all the nannys telling me what I can and can't do. In a way, its more playful and fluid. Feels like the systems are getting in the way of letting the M3 be an M3. GTS Diff - It's hard to distinguish what this changes due to the GTS DCT flash being done at the same time. However, you might as well just do it if you are going to do everything else. I am OCD and I hate when things are "incomplete" or "doesn't match." The whole package above will transform your F80. I was a skeptic. I was reading some forum posts of people saying this and that, but I didn't have time to mess around since today is my day off after working 100+ hours last week and getting out of the office at 2am last night. I wanted to treat myself after a long stressful project was finally over. I decided to pull the trigger this morning without much research and thought. BOY AM I GLAD I DID!!
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race Last edited by hellokitty; 10-17-2017 at 08:53 PM.. |
12
Zermatt88.00 Super Spartan1553.50 Who's on first2464.00 NiceGuyEddie458.00 drgmt984.50 NPuter157.50 SVPREME27.50 Darth One6612.50 qskid2810.50 zero2sixtyZ951.00 Rampage2235.00 davyent10.50 |
10-17-2017, 09:47 PM | #10 | |
Rep 1,338
Drives: Round n' Round
10-17-2017, 09:57 PM | #11 |
Rep 3,726
Yes, 2017 M3 competition package.
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
qskid2810.50 |
10-17-2017, 10:01 PM | #12 |
Rep 1,338
10-17-2017, 10:07 PM | #13 |
Rep 3,726
haha thanks, im a noob
10-17-2017, 10:49 PM | #14 | |
Rep 241
10-18-2017, 11:16 PM | #15 | |
Rep 273
CS EDC, suspension feels a tad firmer with Eibach springs. Less floaty. Will test this out further and GTS MDM/DIFF at an upcoming track event. Most are minor improvements with the exception of the DCT flash which in my opinion is major. |
qskid2810.50 |
10-18-2017, 11:57 PM | #16 |
Rep 20,741
Maybe not in North Korea. As far as I know, the ZCP option code for the Competition Package is only used in the USA.
10-19-2017, 12:59 AM | #17 |
Rep 193
I cannot comment on the GTS DCT flash, but can only attest that I have experienced all of the above mentioned pros of the GTS DCT flash with just a dealer update in late 2016 on my non-CP M3.
10-19-2017, 01:11 AM | #18 |
Rep 241
i'm not following, are you saying that the BMW dealer flash updated your car and it corrected issues with the DCT or they flashed the GTS DCT?
10-19-2017, 06:14 AM | #19 |
Rep 193
The car had 02/2015 software previously. The dealer flashed the whole car to "civic" M3 7/2016 I-level. All of the before mentioned issues with the gearbox were fixed by this. I did not do the GTS flash.
10-19-2017, 07:19 AM | #20 |
Rep 76
This post is really making me think about doing the same thing to my car. Is the best way to find someone that can update my car (also 2017 ZCP) just using the forum? I assume this is not something the dealer would help with in any way, even if they are mod friendly.
10-19-2017, 07:19 AM | #21 | |
Rep 241
10-19-2017, 07:22 AM | #22 | |
Rep 241
