08-22-2017, 07:52 AM | #1 |
Rep 225
Programming a new key?
Hey guys does anyone have a definitive guide to programming a new key from the dealer?
I tried everything I found online and no luck. Thanks |
08-22-2017, 06:30 PM | #3 |
Rep 534
Where did you get the key from? Our keys don't need programming. Can have up to 4 at once. If you ordered the key through a dealer just put it next to the steering column and it will pick up and start working. If you bought a key online it's a paperweight
08-22-2017, 07:11 PM | #4 |
Rep 211
what he said!
Cars are cool. We all know it. You wanna be a real badass? Ride a motorcycle, that's where the real heroes are.
08-22-2017, 07:41 PM | #5 |
Rep 55
Once you unlock the door with the good key, keep it outside of the car. Then you can code the new key like in the youtube videos.
2002 325Ci
2005 330i 2016 M3 |
08-23-2017, 03:42 PM | #6 |
Rep 225
Thanks guys, it's straight from the dealer.
I tried starting the car with the good key then putting the new key to the steering column and still nothing happens. I'll let the dealer sort it out next visit. |
08-23-2017, 04:54 PM | #7 |
Rep 211
hold the key there and continue pressing the start/stop. even just keeping it depressed
08-28-2017, 07:59 PM | #8 |
Rep 487
1. Leave the original key outside of the car (there is no need for the original key for this procedure)
2. Place the TIP of the NEW key against the right side of the column in between the lines where the picture of the key is 3. Keep pressing the start/stop button while holding the key there. You may have to press it numerous times. I have had some work with a few presses, some others took about 20-30 presses. |
08-29-2017, 06:53 AM | #9 | |
Rep 793
Drives: 2022 M4 xDrive Competition
1. Leave the key that works outside the range of the car, I left mine about 20 feet away. 2. "The tip" was important, key must be perpendicular to the steering column. Not flat against it, but with the short edge touching and pointing out. Bit counterintuitive because I thought more surface area would be better, but it wasn't. |
McIntoshMotorSports187.00 |
08-29-2017, 07:07 AM | #10 |
10817
Rep 27,600
keys are programmed at BMW and are tied to a vin.
you can't buy a key from bmw unless its vin matched. if one of your keys is not working correctly then take it to your BMW dealer and they will dial you in no problem as far as getting a key or programing a key from a non BMW store that I can't comment on
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
08-30-2017, 08:32 AM | #13 |
Rep 1,427
Draper just needed to get a new one http://f80.bimmerpost.com/forums/sho...&postcount=200
08-30-2017, 08:40 AM | #14 | |
Rep 3,995
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
firedown31913.00 |
08-30-2017, 09:15 AM | #15 |
10817
Rep 27,600
expensive! shameful plug but you can hit up PARTS@STBMW and Britney will give you a killer quote on a new one. Just know you will need to provide proof (shouldn't be a issue) of ownership before you can buy a new key
PARTS@STBMW2701.50 |
12-22-2017, 08:37 AM | #17 | ||
Rep 5,733
Drives: '24 iX50; '23 i4 M50
Picked up my new M3 two weeks ago, and was only given 1 key, as the dealership lost the other one (or at least that is what they said). They sent me a new 2nd key last night fedex. Of course no one told me I would have to do anything once I received the new key. Sure enough, new key no workie. Check online, watch YT, and the damn thing still never registered. I will be sure to "just use the tip" of the key and keep pressing the start button. Hopefully it works!
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
12-22-2017, 11:38 AM | #18 |
Rep 101
Welcome back! Didn't you just get rid of your 2017 M3 about 4 months ago to go back to the F-Type? Now you're back to another M3!?! I thought I had commitment issues....
BM3 OTS Stage II (Fall / Winter) / Paul Johnson Custom E85 tune (Spring / Summer)
12-22-2017, 12:28 PM | #19 |
Rep 5,733
Cut me some slack...it was 5 months ago!! :
12-22-2017, 03:47 PM | #20 |
Rep 5,733
It worked!!! Thanks guys!
07-02-2019, 01:16 PM | #22 |
Rep 793
