08-16-2017, 08:40 PM | #1 |
Rep 3,386
Remove instrument cluster cover
I looked around for a DIY, but didn't see anything. Is removing the plastic cover for the gauge cluster as easy as removing the two screws? I have dust behind the plastic and want to clean it
Thank you
08-16-2017, 09:37 PM | #2 |
Rep 1,015
08-16-2017, 09:54 PM | #3 |
Rep 3,386
Have you done it?
08-16-2017, 11:41 PM | #5 |
Rep 544
Oh Snap!!,! I won't be taking mine apart....
You guys are funny !,!
1."Luck" is an excuse for people that have failed at their mission to do something! (Allan McNish)
2. I’m not an (EXPERT) I’m just here with an opinion. So don’t hate me. (lukej) |
08-17-2017, 06:48 AM | #6 |
Rep 3,386
Your clearly a bit more experienced then I am haha. looking for a DIY on this as the last thing I want is to make it worse by breaking something
08-17-2017, 02:24 PM | #8 |
Rep 3,386
Does anyone have pics with a setup by step on this? Don't think it should be too bad but also don't want to bite off more than I can chew over a piece of dust ha
08-17-2017, 02:53 PM | #9 | |
Rep 1,015
It really is just 2 screws. I was amazed it wasn't more. Luckily IK6SPEED showed me it wasn't anything more than 2 screws. I wanted to know specifically as I knew I would retrofit a 6WB in the future. I'll be replacing in next 2 weeks and will be happy to post pics of me extracting 2 screws if you want...but I can probably find a similar photo of a person removing 2 screws on the Home Depot website. Pretty hard to "screw" up the Instrument Cluster removal. EDIT: You really didn't search very well Last edited by GCinFLA; 08-17-2017 at 03:03 PM.. |
ArieArie321.50 |
08-17-2017, 06:37 PM | #10 |
Rep 3,386
Thank you, I saw videos for the e90 like you posted, but none for the f80. I didn't realize the whole dash would pull out, I thought if I removed the screws the front cover would just pop off which would be a lot easier
08-18-2017, 05:45 PM | #12 | |
Rep 1,015
Several have stated it is a little tight with M Wheel in place. |
08-23-2017, 09:32 PM | #13 |
Rep 3,386
So now that I put everything back together my heads up display is no longer working. I went into the settings and when I click to enable the heads up display it won't let me the box just Ramon's unchecked
08-27-2017, 07:34 PM | #15 |
Rep 3,386
Your solution in my other thread didn't work unfortunately...
04-29-2021, 01:57 PM | #16 |
Rep 41
Drives: BMW M4 F82
I am about to pull my cluster. I want to try to get some crud off of my lens. Did you ever get your heads up display issue resolved?
04-29-2021, 04:21 PM | #17 |
Rep 3,386
The issue ended up being that I didn't plug the clip in hard enough haha. Really need to force it in. Then it worked like a charm, no coding or anything was needed.
06-30-2021, 09:25 PM | #18 | |
Rep 1
My HUD is making a horrible clicking when I turn the car off (likely "trying" to adjusting the LCD away from direct sun) and I just want to replace it. |
06-30-2021, 09:54 PM | #19 | ||
Rep 3,386
