06-11-2017, 02:53 PM | #1 |
Rep 57
Oil meter after oil change
Hey guys, so I just completed my first oil change on my 08 m3 and I was hoping someone could tell me what this means
View post on imgur.com I used 8 quarts of Castro 10w-60 Thanks! |
06-11-2017, 03:30 PM | #3 |
Rep 57
06-11-2017, 04:07 PM | #4 |
bOrN To DiE
413
Rep 1,738
06-11-2017, 06:02 PM | #5 |
Rep 57
06-15-2017, 05:43 AM | #7 |
Rep 10,614
It may take a few days to get an accurate reading. I usually start by putting in about 8.5L and typically have to later add another 0.5L or maybe even 0.75L.
06-15-2017, 01:31 PM | #8 |
Rep 880
Drives: 2011 E90 M3, 2019 F150
06-25-2017, 07:52 AM | #9 |
Rep 3,450
Hi Guys,
Sorry to hijack the thread, I just changed my oil, and it took 9 litre (Mine is a gts with 4.4 motor) so i dont know if it needed more oil. This doesnt show +1qt , but should be good or needed to reach that middle line ? Thanks
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
06-25-2017, 11:37 PM | #10 |
Rep 479
Gat daymn such low miles lolol. You are good, just in the lower limits of normal. I would try to top it off though. Just do small increments at a time, like 1/4qt, and recheck.
06-26-2017, 06:27 PM | #12 |
Rep 323
Give it a couple days to see if it recalculates the level better. A few times after I have done and oil change my indicator has gone from full to middle back to full over a few days of driving. If its still lower after a few days then I would suggest only adding 1/4 at a time.
06-27-2017, 01:17 AM | #13 | |
Rep 3,450
I dont drive the car much anyways
07-06-2017, 04:24 PM | #14 |
Rep 57
Quick update- so I added another quart and then the meter was nearly 3/4 full after i drove it around a little however 600 miles later my meter looks exactly as it did in my original post.. ive only put 1500 miles since I originally changed the oil (8 quarts used +1 extra quart added 600 miles ago)..
I plan on doing a brand new oil change tomorrow |
07-07-2017, 03:48 AM | #15 | |
Rep 7,109
Some engines burn quite a bit of oil hence your 9 quart over 1500 miles may very well end up with 3/4 gauge while being perfectly in good order. Keep in mind anything above Min on the gauge is fine, be careful with overfill. |
