03-09-2017, 03:16 PM | #1 |
Rep 1,447
For 3.0L-ish 6 cyls cars
The new rs5 features a 2.9L twin turbo V6 making 444hp/443ft-lb. Alfa Romeo giulia qv has same displacement 2.9L V6 making 505hp!!!!! 443f-lb Kinda out-dated our very owned F8x has 3.0L I6 with 425/406 However, they all go to 100kph in about 3.9 to 4.1 seconds. Even big thirsty v8 c63/s is in around same time. What makes the difference??? Weight? transmission? Love 505hp form alfa. The huge steering column mounted paddle shifter is a huge plus! Comparing to small paddle in german cars. Will next m3 boost power to 500? Bmw always seem to be under dog in hp category, but never got outrun (0-100)by higher hp car in the segment. Magic? |
03-09-2017, 07:52 PM | #3 |
Rep 2,134
Because first, none of them make the power they advertise, second, they all weigh different, third the chassis/suspension geometry is different to possibly allow power to be put down more efficiently, fourth, traction/stability control programming, fifth, transmission type/gear ratios, sixth, driver skill.
Get a manual, then you don't need to worry about flappy paddles. FYI, dynos have proven the BMW is actually closer to 470hp at the crank, not 425. Time will tell where the Alfa and Audi land. But V6 = fail anyway. |
03-09-2017, 07:59 PM | #4 | |
Rep 859
Drives: 2017 Alfa Giulia Quadrifoglio
Honestly, the car doesn't feel a single horse faster than 425hp when the virtual drag parachute deploys at 5,000rpm. Just strains with no real force behind it. |
03-09-2017, 08:06 PM | #5 | |
Rep 1,812
Drives: 2015 6MT YMB M3, 1974 Corvette
First set is measured Stock and then with my ACS tuner (uncorrected numbers) M3 Stock at the crankshaft 475 HP M3 Stock at the wheels - 405 HP M3 Stock TQ: 451 M3 ACS tuner module at the crankshaft - 529 HP M3 ACS tuner module at the wheels - 458 HP M3 ACS tuner module TQ - 512
AIRPOWER
03-09-2017, 08:08 PM | #6 |
Rep 2,134
Seriously? It's common knowledge. Nearly all the turbo BMW's have been underrated, the 335 to the M5/6 to the M3/4.
https://www.dinancars.com/product/d4...ries&mid=1178/ Captured here... EDIT: Beat me to it!! Crap |
cotmfk2050.50 |
03-09-2017, 08:14 PM | #7 |
Rep 677
Drives: 458, GTS, Performante
Gearing and total area under the torque curve.
Total area under the torque curve is more important than peak hp, hence all mfgs including Porsche going forced induction. Even forced induction will have different torque curves for different engines and different setups. For instance, one can add an after market exhaust that increases peak hp, but results in slower 0-60 or 0-100 times. An aftermarket exhaust may sacrifice torque due decrease in back pressure for their peak hp gains they advertise, but the net effect is a slower car. Peak hp and peak torque tells story, but not the full story. Total area under the torque curve with a nice flat torque curve is best for accellerstion at this level and at these rpms. |
03-09-2017, 10:59 PM | #8 | |
Rep 1,447
03-10-2017, 02:40 AM | #9 | ||
Rep 1,765
03-10-2017, 07:01 AM | #10 | |
Rep 677
New to BMW, but owned Porsches for decades. Porsche has a long history of underestimating in terms of both output and 0 - 60 figures. Only an immature bench racer who needs to put down the car mags and get a non-virtual girl would make their purchase decision based solely on mfg reported output and estimated performance data. Contrary to your butt dyno you believe sufficiently sensitive to decipher accuracy of real dynos and single hp increments, real dynos show a very impressive super flat power curve. Based on the below, BMW did a heck of a job accomplishing a super flat early torque power curve and overall power curve. In my opinion, this curve maximizes performance and tuning differently to show increasing hp after 5,252 would decrease total area under the torque curve prior to 5,252 rpms. Last edited by 996ttelise; 03-10-2017 at 07:14 AM.. |
cotmfk2050.50 |
03-10-2017, 07:21 AM | #11 | |
Rep 677
I have spent so much time, money and effort with Porsches chasing performance in NA engines. I also had a 996tt with 750 hp also, but the NA arena was my obsession from the 90s until mid 2000s. I built out several flat, air cooled 3.6 to 3.8s and 4.0s, redid internals and utilized stand alone fuel management systems custom made by companies such as Lenz and etc. Learned a lot back then about tuning with the stand alones based on application such as track, acceleration, 1/4 mile and etc. Build or tune to increase area under a nice flat torque curve and hp will follow . . . |
03-10-2017, 10:42 AM | #12 | |
Rep 2,000
As you may be aware, M cars have traditionally been more about a balance of power and handling than about absolute power. As to what your butt dyno is telling you, you're correct in that the F80 tends to feel flat in the upper rpm ranges, especially compared to the E9X cars. Here's why: The formula for calculating power is: torque X rpm --------------- = HP 5252 In any given gear, a car will accelerate according to its torque curve (aerodynamics aside), so the car will accelerate hardest at the torque peak, and less hard above or below that point. So with the exceptionally wide power peak on these cars, the formula dictates that the torque curve has to be falling as you travel through the range of peak power. Therefore, you feel acceleration tapering off as you near the red line. However, at any given vehicle speed, horsepower dictates the rate of acceleration, with max power dictating max acceleration at any given velocity. Therefore, even as you feel acceleration tapering off, you still need to take it to red line, at least in the first two gears, because if you shift earlier, HP after the shift will be much less than at the shift point. In the upper gears, you can shift a little earlier, as long as the rpm after the shift is still within the max power range. Thinking about this, you can see that the F80 puts up very good acceleration numbers for its power-to-weight ratio, because it is at continual peak power from second gear up, unlike most cars. Anecdotally, short-shifting in the upper gears has another mild benefit, because after each shift you have less rotating inertia, thus more acceleration than would otherwise be the case. Bruce PS - Again anecdotally, drivers of E9X cars tend to feel the car accelerates harder at the power peak (8300 rpm) than at the torque peak (3900 rpm), because the torque is dropping ever so slowly as rpm climbs (only about an 11 percent drop over, GOOD GOD!, a 4400 rpm span. Of course, the car's actual rate of acceleration has dropped by only that small amount over 4400 rpm, while the driver's ear dyno is getting pummeled as the car nears red line. Result? Unlike the F80s, the E9X cars get more and more exciting as the revs rise. However, as the aural delight approaching red line fascinates the E9X driver, he'll have to notice the F80 blowing exhaust in his grill, thereby tempering his excitement. |
brava09767.00 |
03-10-2017, 11:08 AM | #13 | |
Rep 677
The flatter, more responsive total area under the power curve is optimal and the F8Xs hit that goal perfectly. People going from a smaller twin turbo or forced induction set up generally say the NA is less exciting, at least in this price range. Something like an LFA, CGT and even a 458 are a intoxicating to me, but that is apples and oranges. Last edited by 996ttelise; 03-10-2017 at 11:27 AM.. |
03-10-2017, 11:19 AM | #14 | |
Rep 621
It's the same reason why a base 991.2 911 with only 350 hp and a better dual clutch than DCT is faster (in a straight and more so track) than an m4 despite a lot less hp, a lot less tq and a disadvantage in power to weight. |
mc3456389.50 |
03-10-2017, 11:22 AM | #15 | |
Rep 621
03-10-2017, 12:42 PM | #16 | |
Rep 859
Drive a Mercedes E63s or Alfa Quadrafoglio and you will instantly feel the difference. However, just don't judge a car based on your opinion without firsthand knowledge. Very accurate review: http://www.caranddriver.com/reviews/...io-test-review Compare that with the Long-term update of the M3: Good, but not great. Best to remain humble with your criticism of the Alfa and upcoming RS5. http://www.caranddriver.com/reviews/...wrap-up-review Last edited by mc3456; 03-10-2017 at 01:06 PM.. |
03-10-2017, 03:06 PM | #17 | |
Rep 677
Some are just not accustom to very flat, ideal power curves that are very linear in feel in power. I have drive the C63S around the track and its torque curve below was pretty consistent to how it felt when I drove it . . . very linear and similar to 2017 M3. In fact, the C63 which you say kicks more and more in the upper rev range falls off harder than the F8X in the upper rev range. Perhaps the butt dynometer is lying to you or we are just making stuff up as we go along? |
03-10-2017, 04:05 PM | #18 | ||
Rep 1,765
If there was a huge drop off of power stock on the S55 after 5k dyno charts would show this, they dont. |
03-10-2017, 04:25 PM | #19 |
Rep 3,341
add drivetrain loss on the throttle on a conventional automatic and the weight, that's the reason the m3/m4 consistently out performs its engine's rated hp compared to the competition.
each component of the car works better together than the separate numbers by themselves. In the f8x's case it is the less weight, great weight distribution, engine gearing matched with the quick shifts of the dct, that allow the car to be both as fast on the track and almost as fast on the drag strip as its competition even 3 years since the car's introduction.
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
