11-30-2016, 03:04 PM | #1 |
BMW obsessed
9587
Rep 10,878
IND | Macht Schnell Boost Metering Block
Any M5 owner interested in serious boost increases has run into a difficulty in getting a standalone vacuum/boost reading from the engine. As with most modern engines, the S63TU does not have spare vacuum nipples which can easily be tapped for a boost reference, making things difficult when the S63TU's boost output is dramatically increased. Now Macht Schnell has created an inexpensive, easy to install solution. The Macht Schnell Boost Metering Block is a bolt-on installation without the need for drilling or tapping into factory charge pipes. Comes complete with O-rings and extended-length screws for simple installation in minutes. The Boost Metering Block is essential for boost readings while on the dyno, or for connecting an analog Boost pressure/vacuum gauge on the dyno. When not in use, the included rubber cap will properly seal the port off safely. Macht Schnell Boost Metering Block: $59 The Macht Schnell Boost Metering Block may be viewed here in our online store: https://ind-distribution.com/product?sku=10.25.100 Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com Read more about IND and our family of brands here!
