08-31-2016, 12:13 PM | #1 |
Rep 21,240
BMW M4 GTS Water Injection System to See Implementation in More Cars
BIMMERPOST NEWS BMW M4 GTS Water Injection System to See Implementation on More Cars According to Autocar, Bosch, the maker of the water injection system featured in the BMW M4 GTS, is now offering the technology to the wider automative market. Beginning in 2019, we'll see the feature implemented in other manufacturer's cars. But, as co-developer of the system, BMW will likely first introduce the water injection system into more of its models. Although the water injection system's primary role in the M4 GTS is to boost power (up to 5%) and prevent heat soak, Bosch says its primary focus is to improve fuel economy and reduce emissions, with a promise of a boost in fuel efficiency by as much as 13% and reduction in CO2 emissions by 4%. A Bosch representative explained that the system Bosch is offering to the market is basically identical to the one on the M4 GTS and BMW's co-operation was highly beneficial to overall development. The representative said: "It's pretty normal thing to have a pilot customer to develop the system together before offering it to the market, and now as we launch to the wider market the system’s costs will come down as volume goes up." |
08-31-2016, 01:05 PM | #3 |
Rep 4,660
Me thinks it'll only be M Performance models while leaving the base and other volume models the same. As cool as it may be, and I'm sure this yields some benefits, I'd rather have a less complex car and not have to worry about another component relating to the engine.
08-31-2016, 01:15 PM | #4 |
Rep 570
This would be awesome on M cars, but might be a bit complicated for the regular series production cars in terms of people forgetting to check the water, adding to the base price of the car etc. ...
BMW Performance SSK, BMW Performance Blackline Tails, BMW Performance Exhaust, BMW 3-Stage Intake Manifold, Evolve Automotive Tune, Weisslicht LED Halos, Black Kidneys, Digital Speedo
08-31-2016, 01:33 PM | #5 |
Rep 8
OEM methanol injection system.... a dream come true
Turbo_power4ever93.00 |
08-31-2016, 01:46 PM | #6 |
Rep 642
Drives: 2010 E92 335i
Perhaps it'll be part of routine maintenance and owners/techs will be reminded to check the water level when doing an oil change or something similar. I'm not sure how often the system needs be checked on the GTS.
08-31-2016, 01:53 PM | #7 | |
Rep 325
The bigger risk to me is people in regions of the country with hard / soft water not using distilled water causing deposits and potential engine damage. |
bradleyland1503.50 |
08-31-2016, 01:55 PM | #8 | |
Rep 3,341
distilled water only. i have a feeling people will fill it up with tap water and break it. just doesn't seem like a good idea for the general public.
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
08-31-2016, 01:55 PM | #9 |
Rep 20,741
Drives: 2021 911 turbo
IIRC from the GTS literature, BMW estimates one water fill up for 5 tanks of gas with street use and a water fill-up with every tank of gas with track use. Sport Auto almost emptied the water tank after only 2 laps of the 'ring. Checking the water level through maintenance will just not cut it .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
08-31-2016, 01:56 PM | #10 |
2006 TIME Person Of The Year
9720
Rep 6,445
How large is the tank going to be? What happens when the vehicle is parked outside and the temperature is well below freezing?
Fake News 2017335.50 |
08-31-2016, 02:03 PM | #12 | |
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
FSociety3812.50 |
08-31-2016, 02:04 PM | #13 | |
Rep 1,523
08-31-2016, 02:07 PM | #14 | |
Rep 4,724
BMW953.00 |
08-31-2016, 02:07 PM | #15 |
Rep 1,523
When the temperature is near freezing. The water injection system is automatically disabled by the car. Also each time the car shuts off, water in the pipes gets pumped back to the tank. They did winter testing to make sure the water freezing will not burst any plumbing. They also had the water tank filled with water and put it into a freezer to make sure it can expend without cracking.
08-31-2016, 02:30 PM | #16 |
Rep 20,741
08-31-2016, 02:33 PM | #17 | ||
Rep 137
08-31-2016, 02:43 PM | #18 |
Rep 862
Drives: '19 M2 '21 X5
As a Canadian, my primary concern is how they are going to handle having a tank of water inside the car in the winter...
if you could mix a bit of meth or ethanol in it would probably be OK though. If they do straight disable near freezing, well that would suck. I know a lot of people who dd M cars through freezing winters. I know i run mine all year long, even did an ice track last year and it would be pretty dumb if the car was power retarded 6 months of the year. |
Dog Face Pony Soldier9719.50 |
08-31-2016, 02:55 PM | #21 | |||
Rep 155
Drives: 2007 E92 335i TIAG
The carbon buildup started at the n54 and continues through all of the newer models. BMW has yet to introduce dual port injection to any of their models, and considering almost every car in their lineup now has forced induction (turbo power) coupled with direct injection, carbon buildup is far from being a thing of the past. I personally have seen it on N55 models, as well as N20 engines. IMO this would be just another expense added to cars that do not need it. A GTS model is understandable considering every bit of HP counts but to a car that is used as a daily driver, kind of pointless, the fuel economy line is a selling point more than the truth.
2008 335i 6MT (RIP)
2007 335i JB4 G5, BMS DCI, ER Chargepipe, VRSF 3" Cattless DP |
08-31-2016, 02:57 PM | #22 | |
Rep 3,456
Drives: Harrop E90 M3
