08-14-2016, 09:13 PM | #1 |
Rep 94
Update my Nav software
I bought Nav updates from my BMW dealers parts dept and the updates are not being recognized when I insert the stick into the USB port. The dealer then ordered another version and that didn't work either. I have a strange feeling that my dealer doesn't have a clue what version my car needs. I know that my USB port works because I am able to play MP3's and also connect to my iPhone and use the Spotify and Pandora apps via connected drive.
Does anyone know how I can find the right Nav update for my 2016 M4 Coupe and just buy and download it? |
08-15-2016, 02:45 PM | #2 |
Rep 6,248
You bought a map update from you dealer? The MY2016 cars get free map updates, over the air.
Get a refund, ASAP. https://www.press.bmwgroup.com/usa/a...language=en_US |
08-15-2016, 03:28 PM | #3 | |
Rep 2,385
08-15-2016, 03:33 PM | #4 |
Rep 6,248
I'm in Texas too. When there is an update available, you can pick your states (regions?) that you want the system to download.
08-15-2016, 03:39 PM | #5 | |
Rep 2,385
Also, I think this is M3 only - he's got an M4. Could be wrong, but your link mentioned this OTA updates for the M3, but not the M4. |
08-15-2016, 07:31 PM | #6 |
Rep 6,248
MY2016 M3 & M4 have the same behavior.
08-17-2016, 03:28 PM | #7 |
Rep 14
Hi! What a coincidence!
I just updated the maps today on my M4! So basically, if you register your car on the bmw Connected Drive Portal, now with the new web-design (at least in EU is a new one ) you are able to download a software called BMW Update Manager. In addition to it, you must download a file that is also present in the website. That file (extension .bmwm) contains the map information for your car! As so, once you install the BMW Update Manager, you double click that file and it will start to download the new maps. For me, EUROPE 2016-2 was around 24gb! Once the software finishes to download, it asks you for a USB key. Once you put the USB key, it will start to extract the maps inside the USB. After the extraction is complete, you plug in the USB in the car and automatically you will receive a message saying something like "new maps available, do you want to update?" and you hit yes! and it will do it. For me the whole update process took around 30m. For your issue, did you try to connect it to the USB on the gloves compartment? Perhaps it does something different! Hope it helped. Thanks |
08-23-2016, 10:40 AM | #8 | |
Rep 6,248
08-23-2016, 12:06 PM | #9 |
Rep 2,385
You still need USB updates if you want to update the full maps - the over the air updates only update 1 region.
08-23-2016, 12:24 PM | #10 |
Rep 6,248
08-23-2016, 12:26 PM | #11 |
Rep 2,385
08-25-2016, 08:57 PM | #12 |
Rep 237
Agree that i was only able to select one region. I live in an area that borders two regions. I found that I select one of the regions and let that one update....Then I go in and select the other. I end up with both updates. Wish there were a better way to get multiple regions to update. This method takes way too much time and is a pain in the butt.
2016 ///M4 F83, SO/black, DCT, EXEC, Driver Assistance+, LED, BLK 19"s, M Adaptive susp (Basically everything but the Carbon Brakes)
09-01-2016, 08:36 PM | #13 |
Rep 94
Meanwhile my BMW dealer hasn't figured out how to updated maps on my 2016 M4 (North America).
Can I just buy the thing online from BMW and install it myself? Last edited by mapexvenus; 09-02-2016 at 07:15 AM.. |
09-02-2016, 06:14 AM | #14 | |
Rep 4,703
09-05-2016, 04:08 PM | #16 |
Rep 6,248
Automatic map updates. You don't pay.
Also, go to www.connecteddrive.bmwusa.com and make sure you have a region set. Last edited by SamS; 09-05-2016 at 04:15 PM.. |
09-05-2016, 04:18 PM | #17 | |
Rep 2,385
09-05-2016, 04:27 PM | #18 |
Rep 6,248
There is an FAQ on the site which seems to imply you can only pick one region. However, it remains to be seen if you pick one region (i.e. Texas) for one quarterly update, then switch to another region, if it will keep your previously-updated region, while also updating a second region. That way you could alternate updates between a handful of regions. I suppose someone would have to find an update where they can pinpoint an exact change between one update and the next, then try my strategy above, then check afterwards.
