08-01-2016, 06:56 PM | #1 |
Rep 224
Cooling problems, of course...
Long story but I'm in need of help!...So I was recently hit with the common cooling issues of the N52 water pump/ thermostat combo. Got an engine light last week code read that the thermostat was stuck. Figured I would just order the whole refresh kit, swap it all out and call it a day. While waiting for the kit, I drive roughly 15 or so miles to work everyday, on the way back one day going maybe 70-80ish the whole way, I overheated. Slowed it down, was fine for the day. Fast forward to when I get the kit, I swapped out the pump and thermostat, pretty straight forward and simple change, went to do the self-bleed procedure...and nothing happened...tried a slightly more unconventional way to bleed the system, and immediate overheat upon the car hitting operating temperature. Reinstalled all the old parts, tried the self bleed again, and nothing...called my brother whom owns the same exact car to try to do the self bleed on his, and nothing. I finally go to an indy shop and they tell me that the self bleeding procedure is basically just a myth, and that they have to hook their super computer up to it so that it can work it's magic and bleed the system. I'm essentially all out of ideas, did all the googling I could and haven't seen anything about the bleed procedure not ever working, so maybe this is a dumb question but are they blowing smoke up my ass or is that what I'm going to have to do. Any help is very much appreciated!
08-01-2016, 09:48 PM | #2 |
Dog Listener
707
Rep 7,850
When you say self-bleed you mean one of these?
http://www.pelicanparts.com/BMW/tech...ing_System.htm http://wiki.bavariantechnic.com/inde...leed_Procedure |
08-01-2016, 09:58 PM | #3 | |
Rep 224
08-01-2016, 11:09 PM | #4 |
TARDIS
12
Rep 58
Do you mean the technique to start the electric water pump?
I changed my water pump and thermostat as in this thread. http://www.zpost.com/forums/showthread.php?t=1284903 The old water pump would not turn on with the following technique but the new one did. http://www.zpost.com/forums/showthread.php?t=1289922 |
08-02-2016, 07:07 AM | #5 | |
Rep 224
08-02-2016, 09:15 AM | #6 |
Rep 222
The self bleed procedure is real-- used it several times on my cars.
Sounds like a dishwasher is starting up under the hood.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters |
08-02-2016, 12:51 PM | #7 |
Rep 224
See and that's what I've seen in all the videos and such, I just can't get it to work. But both of my pumps being bad as well as the other cars just seems pretty unlikely... so would the verdict be that the indy shop is blowing smoke up my bum or what?
08-23-2016, 10:27 PM | #8 |
Rep 45
Drives: 2007 Z4 Coupe
My pump was quiet and we did it several times thinking it wasn't working. Here is a link to my experience: http://www.zpost.com/forums/showpost...15&postcount=5
08-24-2016, 01:11 AM | #9 | |
Rep 224
As for your experience, I know the feeling trying to limp home. Luckily I had a friend with a spare car to lend me for the time being. Glad you got it all fixed! |
08-24-2016, 08:08 PM | #10 |
Rep 45
Glad you got it sorted. Nothing will make you enter brown town faster than cooling issues.
08-25-2016, 09:39 PM | #11 | |
Rep 758
Glad they finally checked and got you back on line!
Top Down 365
