07-21-2016, 07:50 PM | #1 |
Rep 204
headlight paint is peeling due to painting them black sapphire metallic..need help!
I had the inside housing of my headlights painted sapphire black metallic like my car (2007 bmw z4 coupe) and they have bubbled up and made the headlights shine all over the place. I wish I would have known this before I made the decision to paint them this color. I want to take them back apart and paint them the STOCK black that they use. Does anyone know if this would work if I strip the paint off and use whatever stock paint it is or do I have to buy completely new headlights? I had Erik from Tekarbon do this with angel eyes as well. Thanks in advance.
07-21-2016, 09:00 PM | #2 |
Ammar
73
Rep 406
Im sure the paint color itself wasnt the issue, but moreso the paint itself. Not much help but it was worth mentioning.
E85 ///M Roadster -SapphireBlack/Imola - Garage Queen
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
07-22-2016, 07:46 AM | #4 |
Rep 500
If I understand what you are saying, this is a common issue with painting the inside housing. It's a heat thing. Getting a proper bond to the plastic has been something DIY-ers have been chasing for a long time, not just with BMW's. The headlight heat causes the paint to delaminate. I had the same issue when I did my Mini Couper S.
07-22-2016, 09:42 AM | #5 | |
Ammar
73
Rep 406
07-22-2016, 07:34 PM | #6 | |
Rep 204
07-22-2016, 11:21 PM | #7 |
Rep 2,551
Drives: Z4MC-X3-35i-525i, Corrado G60
The paint bubbling on the reflector shouldn't make the "headlights shine all over the place". The bi-xenon projector works independent housing around the headlight so that shouldn't effect the light output at all. Regardless, it must look like crap. I would have thought Tekarbon would have known if the paint would have held up or not before they did they work. Did they say anything about using automotive body paint for inside the headlight assemblies?
I put bi-xenon projectors in my S10 pickup with standard 4"x6" rectangular headlights and painted the chrome reflectors with black high temp BBQ paint. The paint has been on there for many years and has not bubbled or peeled and those headlights assemblies are tiny and get much hotter then the large Z4 headlight assemblies. |
07-23-2016, 02:25 AM | #9 | |
Rep 204
07-23-2016, 02:31 AM | #10 |
Rep 204
Also, the housing is chrome because it extends the width of the beam. I think that's why my lights are looking all messed up and all over the place. I hope after I paint them again with whatever I decide to use will fix this issue somehow.
07-23-2016, 08:13 AM | #11 | |
Rep 41
07-23-2016, 09:36 AM | #12 | |
Rep 2,551
Any good hardware store should carry it. It's all about proper prep. No, the chrome does not extend the width of the beam, the projector does that. The beam pattern of the projector is the same whether it's in the headlight assembly or on a workbench. The Chrome is cosmetic. Some of the headlights have black housings. Last edited by pungo; 07-23-2016 at 10:53 AM.. |
07-23-2016, 10:58 AM | #13 |
Rep 779
you can get high temp bbq paint anywhere, home depot, etc amazon
http://www.homedepot.com/p/Rust-Oleu...8502/100645381 http://www.homedepot.com/p/Rust-Oleu...8830/202315061 - spray. so issue is some paint etches, they will eat plastic.. you better test before you commit and see your headlight melted by the paint https://www.amazon.com/Rust-Oleum-24...ords=bbq+paint amazon - prime it
-Roranji
07-23-2016, 11:15 PM | #14 |
Rep 204
I just wasn't sure about spray painting the housings on these headlights. I guess if it works, I'll go for it. How many coats/cans of spray paint did you use for the lights? I'm going to take them apart tomorrow, I just figured I would have to spend a bunch of money on some high temp high quality black paint somewhere, but if this works I guess not.
07-24-2016, 09:06 AM | #16 | |
Rep 2,551
Why aren't you going back to Tekarbon to fix them since you probably paid a large sum of money for them to do work that failed? Do they not warranty their work? |
07-26-2016, 10:44 PM | #17 | |
Rep 204
