BMW M3 Forum (E90 E92)
      07-09-2016, 12:53 PM   #1
Owens84qv
Drives: 2011 335xi, Ferrari 308QV
Differential Side / Axle Seal DIY?
While inspecting the underside of the M3 this weekend, noticed the passenger-side Differential side / axle seal was leaking. I searched for a DIY to replace this and wasn't able to find anything. Anyone know of a DIY?
Thank you!
      07-11-2016, 09:37 PM   #2
ec_E92
Enginerd
Drives: E92M3,E36M3,957GTS,E39M5S2
Don't have a diy and no affiliation but check out bimmerdiffs.com for parts. I tore apart mine several years ago for a failed input shaft bearing, it's not hard but not easy either.
2008 E92 AW 6MT /// 120k orig rod bearings
      07-12-2016, 10:31 PM   #3
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
My guess is to remove the output shaft via the 5 torx bolts, drain your diff, then undo the hex bolts, and replace 8-12 http://www.realoem.com/bmw/enUS/show...diagId=33_1418
You could probably get away with just replacing #12, but it's a "while you're in there" type of job so why not do the rest?
Refill your diff fluid
In order to drop the output shaft, you're going to have to drop the exhaust too
      07-15-2016, 11:57 AM   #4
e92zero
Drives: 2011 E92 BW
I don't have a DIY but I just did this on both my left and right seals not too long ago. You can reference any BMW Diff seal replacement diy/video online as they are pretty much the same:
- drop exhaust
- remove the 6 torx bolts for the drive shaft (along with the plate), they are suppose to be one time use only. Tightening torque are 120 Nm.
- pry off the flange, should be easy
- I was not able to remove the seal from the covers here while it's still on the diff so I ended up removing the cover as well. 8 hex bolts. Tightening torque are 21.7 Nm. This cover fits very very tightly and is there to actually position and hold the diff gears inside. If you do take off this cover, mark the orientation as there is a breather/oil supply hole inside. (I am not sure it matters as long as it's up but just mark it so you can put it in the same). The shim is also specific to the individual side so don't mix them (left vs right if you are doing both seals).
- I ended up having to use a press to remove and install the seal on the cover. Note how far the seal goes in. It is NOT suppose to bottom out and only cover the oil supply hole maybe 1/2 way. You will know what I mean after you look at the cover more closely. Just remember how far in the old one was and press in the new one the same depth and you will be fine.
Put everything back in reverse order. It's gonna be very hard to put a torque wrench in there to tighten the 6 torx bolts if you are working on it under the car. Having someone to help you hold the brake while you rotate the flange/shaft would save you a lot of time and backache. I didn't have help so I have to rotate wheel, get in car, pull handbrakes, get back under and tighten the bolts in cross patten. Repeat for all 12 bolts at a 3 step process because I don't want to tighten them to 120 Nm in one shot. My back was not happy.
Good lucky and let me know if you have any questions.
Theodore668.50
      07-17-2016, 03:57 PM   #5
mharris2007
Need a 458
mharris2007's Avatar
51
Drives: 2008 AW 6MT E90 M3
- drop exhaust
Super helpful description for all of us. Thank you.
      03-09-2019, 08:14 AM   #6
Theodore
Theodore's Avatar
Drives: 2011.5 E92 M3
For cross reference, here is a link to a DIY guide for this job.
What I Wish I Knew When I First Bought My E9X M3 Can Be Found Here
E9X M3 Exact Original Equipment (OE) Equivalent Parts Can Be Found Here
E9X M3 Common Torque Specs Can Be Found Here
E9X M3 "Factory" Tools Can Be Found Here
m3post
