06-30-2016, 03:36 PM | #1 |
Rep 917
Road rally suspension setup
Have you seen or participated in things like Gumball 3000? This is where there is a meeting spot somewhere, usually inside a large city, then a race to different checkpoints. Usually the roads are terrible in the city and the highways, then you have serious twistys to contend with. I just participated in something like this and it was an incredible experience, even though my ride ended way short of the finish (water pump). This exposed a huge shortcoming in my setup, the suspension. I cheaped out big time in this department. I'm just running Eiback Sport Springs with OEM struts + Whiteline subframe bushing inserts. I know, stupid decision not to replace the struts. I guess my biggest complaints are the harshness when hitting large road imperfections, and the inability to get power to the ground on rough sections. On smooth back roads it actually feels pretty good. The sticky tires I have really grip well. What would you guys suggest I do to nail down a good suspension combo with rally's in mind that won't completely break the bank, or my spine?
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
06-30-2016, 04:40 PM | #2 |
Rep 750
Drives: '98 Z3M (gone), '09 135i
I like the e92 bmw performance shocks + e92 dinan springs. Needed the ride height so I wanted as little drop as possible. I did the shocks first, but it just didn't feel as hunkered down as I wanted it to be. My goal was something that would be good on back roads of NJ and PA. Anything is an improvement over the stock shocks though.
Maybe konis would be right for you to have the dampening adjustment. |
06-30-2016, 05:10 PM | #3 | |
Rep 917
06-30-2016, 05:11 PM | #4 | |
Rep 750
All the mid range ones lower the car a 1"+ iirc, which wouldn't be good on the rough stuff, but you may be able to swap in different springs to change ride height. |
06-30-2016, 05:14 PM | #5 | |
Rep 1,233
A cheap out of the box kit would be something like a B12 kit (you would just need bilstein B8s since you already have the eibachs) or an equivalent koni based kit. All depends on how much cash you got to spend... |
06-30-2016, 06:04 PM | #6 |
1Addict
3236
Rep 7,897
Absolutely love my TCK SA setup. If you want to have the option of keeping the ride height near stock levels, use the OEM top hat.
06-30-2016, 08:34 PM | #7 |
Rep 917
I see the name TC Kline come up a lot when looking at reviews and recommendations. $2,200 is a bit more than I'd like to spend though. I might just go with the Koni's struts for now and pine over the TCs for another year or so before I give in and get them.
06-30-2016, 08:41 PM | #8 |
Rep 917
How is it compared to the Bilstein HD Dampers, Swift Spec-R Springs that you had? That's what's listed in your build thread.
06-30-2016, 08:54 PM | #10 |
Rep 1,004
06-30-2016, 09:02 PM | #11 |
1Addict
3236
Rep 7,897
Better valving, rebound adjustment is nice too. Though the Billy/Swift setup was great as well. Still need to take pictures of those parts and put them up for sale. Update my build thread too. Been super lazy lately.
06-30-2016, 09:08 PM | #12 | |
Rep 917
07-01-2016, 08:25 AM | #13 |
Rep 917
I can't remember, can you change just the struts without an alignment?
07-01-2016, 10:59 AM | #14 |
1Addict
3236
Rep 7,897
If you change the front you'll need an alignment. In general you'll need one if you touch any of the adjustment points or change the ride height at all.
07-01-2016, 11:59 AM | #15 |
Supreme Allied Commander
3858
Rep 54,419
Drives: F80 M3
TCKR is a very good choice as both the struts and shocks have additional compression travel. Spring rates also have several options to suit your needs. Ride height can be nearly stock or lower depending on spring selection. Camber plates are purely optional with the TCKR.
PM or call us if you have any specific questions. |
