BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      06-11-2016, 09:55 AM   #1
MTM
Drives: 2009 M3
DIY: How to replace lower control arm
EDIT 24 August: added reply with DIY steps
The bushing on my lower control is degrading so I am looking to replace it.
Two questions:
1. Does anyone have a guide on how to remove / install? I don't do much suspension work and am not that familiar with this kind of activty.
2. For daily driving and Occasional track use, should I bother with the upgraded bushings? Am thinking of just buying a replacement control arm from ECS or GetBMWParts...is an upgrade worth it? Am a little worried about pressing out the old bushing and pressing in a different one as opposed to just swapping out the assembly.
Thoughts?
      07-05-2016, 09:08 PM   #2
MTM
Drives: 2009 M3
Hello? Is this thing on?
      07-05-2016, 09:18 PM   #3
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
I would rephrase the title. I doubt people read the title and can tell you have a question.
      07-08-2016, 06:59 PM   #4
MTM
Drives: 2009 M3
Good call...will see if the rephrased title gets a little more air time.
      07-24-2016, 07:05 PM   #5
Bengineer330
Bengineer330's Avatar
Drives: Le Mans Blue 2011 E92 M3
Is this what you are referring to (red arrow)? I bent mine at the last track day i was at. Ordered one yesterday, should be here Wednesday. Planning on replacing it this weekend. If that's what you are talking about let me know and ill make sure to document the process.
The Bad One
The Good One
2011 E70 Xdrive50i M-Sport Black
2011 E92 M3 ZCP LeMans Blue
2006 E90 330i Silver - Donated after 410,000 miles
      07-25-2016, 07:10 PM   #6
MTM
Drives: 2009 M3
Yes, that's the one!
      08-07-2016, 09:41 AM   #7
vm
Drives: 2018 Alfa Romeo Giulia
There is a guide in the e90 3 series forum and should be very similar to your M.
www.e90post.com/forums/showthread.php?t=788761
Also this one for the "Tension Strut"
www.e90post.com/forums/showthread.php?t=778726
      08-23-2016, 05:36 PM   #8
MTM
Drives: 2009 M3
DIY Edits
So I did the job this weekend. Assuming I did it correctly, the job was actually very easy.
Tools Used:
21 mm box end wrench
18mm box end wrench
18mm ratchet (open socket wrench or a deep socket)
T-40 Torx bit
(Small sledge to break loose the nuts)
Overall Steps to Remove:
Jack up car, be sure to keep wheel supported (don't let it hang loose)
Loosen 21 mm nut on vertical stud of control arm (near wheel)
When stud begins to spin, grasp 21mm nut and use T-40 on top of stud
Remove 18mm nut near car frame (the bushing end of the control arm)
Reverse the above to install.
CAUTION: the left and right lower control arms look nearly identical! The only difference is which end the offset bushing protrudes from the arm. I missed this and got to do the passenger side two times (ugh!).
Once you know what to do, the job only takes about 30 minutes. Maneuvering the bushing end of the control arm in and out of the frame bracket can take a little patience.
The pic below shows the 18mm box end wrench and the 18mm open end socket on either side of the bushing stud.
      10-02-2016, 10:18 PM   #9
drwankel
drwankel's Avatar
1042
Drives: 2012 E92 M3 ZCP, 2021 M340i
One thing very commonly overlooked, is any bushing needs to be tightened when the car is on its own weight.
If you tighten everything up when you are in the air, you are preloading the bushing, which creates a number of unintended consequences.
      11-23-2016, 08:13 AM   #10
simpleM3
simpleM3's Avatar
165
Drives: 06' E46 M3 ZCP
19’ BMW M5C  [0.00]
2007 E61 530XI  [0.00]
2006 E46 M3  [0.00]
Part number for lower forward control arm?
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell
03' E39 M5 | 100% Stock
      03-18-2017, 12:27 PM   #11
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Would that still apply if I am installing control arms with mono ball bearings instead of bushings?
      03-18-2017, 12:35 PM   #12
kamber
E90
167
Drives: '08 M3
Uh oh. I did NOT do this when I installed my Bimmerworld lower control arm bearings. Havnt felt any negative side effects in the last 500 miles of street driving though.
Not quite sure how I would even get under it to tighten it if the car was on its own weight.
      03-18-2017, 12:38 PM   #13
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
I was thinking the same thing, but came to the conclusion that it should be possible if the front wheels are up on ramps.
askme80.50
      03-18-2017, 12:41 PM   #14
kamber
E90
167
Drives: '08 M3
Hrm, true. I only have access to a 4 post or 2 post lift and have never worked with ramps before. Hopefully it's a non issue since our new bearings do not flex like the stock bushings can.
      03-18-2017, 12:46 PM   #15
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Ha! Finally a win for the weekend warriors on ramps/jack stands!
Lol but for real I want a lift so bad, I'm jealous.
But anyway, you're probably right.
      03-18-2017, 01:30 PM   #16
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
Drive that side of the car onto the curb from a driveway apron
      03-18-2017, 02:52 PM   #17
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Ok, FWIW, I just talked to my friend who's a Nissan master tech and he was saying the reason you aren't supposed to torque down a rubber bushing without load is because the control arms will twist/turn slightly once you set the car down and since rubber bushings are not made to turn inside the "socket" the rubber will just twist which can cause them to crack/break prematurely due to constant stress. But since bearings are made to turn, then it's no issue!
      03-18-2017, 04:10 PM   #18
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
+1, the arm twist once the car is back on all 4's.
What I do is lower the front onto ramps, crawl under and torque it down.
      07-10-2018, 02:40 PM   #19
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
how many of these self locking nuts would I need? I will be taking out the control arm bushings and installing stiffer bushings then puting the original control arms in again.
https://www.ecstuning.com/b-genuine-...h/33326760668/
      01-21-2019, 03:41 PM   #20
byroncheung
Drives: e90 m3, 997.2 c2s, x166 GL450
great info... what are the torque specs?
      01-27-2019, 06:29 PM   #21
StogyBear
Drives: 2012 E92 M3
They're different sizes. Look up the part number on realoem. You also need new bolts I think.
      05-22-2021, 01:33 AM   #22
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
I'm doing the control arms based on the FCP Euro video on it, but struggling to take off the tension strut on the T40 bolt side. The bolt will not spin at all, broke 3 T40 sockets on it.
Any tips for getting it off? Thinking of resorting to an impact wrench and a T40 impact socket, but that might strip the bolt and cause a bigger problem.
m3post
