04-30-2016, 02:38 PM | #1 |
Rep 527
Drives: 2011 E82 135i, 2015 F15 X5 35D
Brake output wire for brake controller
Hey guys, I bought the draw tite hitch and a wiring harness from etrailer along with the prodigy RF brake controller. The wiring harness has a 4 flat connector which I just realized will not work with a brake controller.
My question is does anyone know where the brake output wire is located in the F15 X5? Is it located in the footwell where your brake pedal is located or is there one in the trunk which would be very convenient so I do not have to run a wire to the front of the car. I know I need a 4 way to 7 way adapter plug and I know where to connect the black power and white ground but I do not know where to connect the blue brake output wire. Thanks in advance. |
05-01-2016, 07:08 PM | #2 |
Rep 938
In the trunk. does this help? i dont remember a blue wire with the execuhitch
https://www.bavauto.com/Assets/inst_pages/ins370.pdf |
05-01-2016, 07:11 PM | #3 | |
Rep 527
05-02-2016, 06:25 AM | #4 |
Rep 938
There isn't an adapter. There are 2 fuse points to tie into and a 2 pin adapter on the poet section of cable, wrapped in black tape. Also a power and ground connection. Etrailer may have an adapter for the 2 pin connection. Also you typically need another module added did you get that?
05-02-2016, 09:21 AM | #5 | |
Rep 527
05-02-2016, 09:22 AM | #6 | |
Rep 527
