04-08-2016, 02:47 PM | #1 |
Rep 38
Coolant flush and fuel service during maintenance
I was told by service that we should be doing a coolant flush every 3 years? I have heard some differences that BMW offers lifetime while some say to change it every 3 years. My car is under maintenance and they were also trying to charge me for it.
Anyone have experience with this? Is it needed? |
04-08-2016, 02:59 PM | #2 |
Well versed in the care and feeding of BMWs
261
Rep 733
Coolant needs to be changed periodically. Depending on your operating conditions this could be as frequently as every other year or so. All of my vehicles have the coolant exchanged every 2 years. Very rarely do I incur coolant system failures when I travel.
B&O, parking assistant, executive package, 3rd row seats and the manual rear shades are the ONLY items we didn't order. Having everything else makes our F15d a NICE ride.
04-11-2016, 10:48 AM | #3 |
Rep 409
I think the official BMW spec says ~ "coolant is lifetime unless service is done to the cooling system" (like new water pump, radiator, or hoses). So, free maintenance won't pay for coolant changes.
That said, I would / do change mine every 4 years. (I do brake fluid every 2 and coolant every 4, easy to remember that way). You should pay to have it done if you don't DIY, it is money well spent. Most BMW engines also have a coolant drain on the block. So if you drain the block and the radiator, you get 99% of the fluid out. You don't need to pay for any "flushing machine" or other fancy service. I do only use original BMW coolant and distilled water.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
04-12-2016, 11:40 AM | #4 | |
Rep 38
04-12-2016, 12:39 PM | #5 |
Mmmmm…
1150
Rep 2,426
Drives: F15
You don't need fuel service this early unless you use really crappy gasoline.
Coolant flush shouldn't be $210 but that sounds about right for dealer service. |
04-12-2016, 01:36 PM | #6 |
Rep 458
Tell them that you are a huge environmentalist and ask to test the coolant and provide you the results. There is a cheap meter that tells you if the coolant needs to be changed - BMW should have the tool and should not charge if they are t recommending to change. That is, question their basis for the change.
05-10-2020, 11:23 AM | #8 | |
Rep 121
ponytuning120.50 |
05-10-2020, 12:17 PM | #9 | |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
The other thing a flush does is get rid of sediment in the system. Those little particles cause abrasion of seals and impellers. $180-200ish is a reasonable dealer price. Last I checked these cars need about $30 in coolant and distilled water, plus disposal of the used coolant and about 30 minutes of labor to change and purge the system of air. |
05-10-2020, 12:19 PM | #10 | |
Rep 359
05-10-2020, 02:09 PM | #11 |
Rep 121
Also in case you need air purge tool, that is what I'm using.
https://www.ecstuning.com/b-schwaben...l/003466sch01/ |
ponytuning120.50 |
05-10-2020, 04:43 PM | #12 | |
Rep 359
LE: Found it! https://www.newtis.info/tisv2/a/en/f...eck/1VnXhWsfEx LE2: Does the coolant for the charge air cooler (on the passenger side) also need to be drained/bled at the same time as the engine coolant? Last edited by ponytuning; 05-10-2020 at 05:08 PM.. |
