04-07-2016, 10:54 PM | #1 |
Rep 7
X5 35i dash cam installation help!
Try to put a dash cam in the car, and hardwire in the fuse box on the passenger side, so it can be parking mode. But don't know which fuse wire on, any recommend fuse to use?
04-07-2016, 11:15 PM | #2 | |
Rep 18,715
08-12-2016, 10:59 AM | #4 |
Supreme Being
1804
Rep 5,425
http://f15.bimmerpost.com/forums/sho...hlight=Dashcam
I'm off to have a read now as I had the Thinkware in my F30 and need to plan for reinstall in the F15 in a few weeks. PDF file: http://f15.bimmerpost.com/forums/att...2&d=1418781422
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
SMC23180.00 |
08-12-2016, 02:31 PM | #6 | |
Rep 518
08-12-2016, 06:45 PM | #7 | ||
Supreme Being
1804
Rep 5,425
04-05-2017, 08:21 AM | #9 |
Rep 2,558
First of all, thanks to r33_RGSport for the DIY. Threading the wire for the rear view camera was a PITA.
But I got it all wired up now. Problem is that the DIY's that I'm finding online all connect to the full size ATO fuses, but per blackboxmycar, I was provided with a mini-fuse fuse tap (their Add-A-Tap wire). I tried using the 150 fuse as it was trunk related, but it appears that's a constant power fuse, not an ACC fuse. Does anyone know which mini-fuse would work that is ACC (only on while ignition is on, but turns off when car is off)? Thanks! |
04-05-2017, 03:39 PM | #10 |
Rep 592
Just did mine several months back. I'll check my rear fuse panel setup when I get home in 4 hours.
UPDATE: I tapped into fuse slot 143 using a mini fuse tap. Good luck. Last edited by Neuera09; 04-05-2017 at 09:47 PM.. |
