04-06-2016, 01:01 PM | #1 |
Rep 29
Help with Lowering, Spacers, and wheel size please
Hey everyone. I'm a new X5 owner, xDrive 50i M Sport. I've always lowered my rides and put larger wheels with no issues whatsoever. But I've been researching on here regarding lowering the X5 and changing wheel size and I've been finding so many contradictions with the opinions on here. Just hoping someone can provide clarification.
So, I have the Hamann suspension and exhaust, and I purchased some 20"x10" fronts and 20"x11" rear wheels. There is one picture floating around on this forum of a white X5 that's lowered and the 20" wheels are sitting sooooo far inside the fender that I can't stand it and people keep saying this is what it looks like if you lower the X5 without spacers. But my question is how could I be going from a 9" width rim to an 11" wide rim and not be filling that space better? And how could lowering it just 1.1" in the rear and 1.8" in the front be so detrimental to the wheel arch spacing? Every other car I've lowered and put wider wheels on just looks fantastic, drives great, and has no need for spacers. Is this not the case with the X5? Do I need spacers too? |
04-06-2016, 01:22 PM | #3 |
Rep 29
04-06-2016, 03:05 PM | #4 | ||
Self-Deprecating Narcissist
7266
Rep 6,561
20x10, 275.40.20 et40 front 21x10, 285.35.21 et40 front 20x11, 315.20 et37 rear 21x11.5, 320.21 et38 rear yes. 20, 25 or 30mm. on a 469m wheel the 20mm will push it about 3/4" out, 25mm 1" and get you nearly flush, 30mm will put you out ~1.25" a hair past the extended fender trim depending on how squared off the tire is. 12mm Front 15mm Rear: *Please purchase the appropriate wheels bolts which match the amount of spacing you're offsetting the wheel by.
04-06-2016, 04:34 PM | #5 |
Rep 29
Damn that X5 looks awesome. Thanks for the info man. So do I have to wait and get everything measured befor I order the spacers or can I just take your recommendation and get me some 25mm spacers? Never had to use them so this just confuses me a little bit. I appreciate your assistance.
04-06-2016, 04:47 PM | #6 |
Rep 18,715
It is all in the math.
If you have the specs, I can do the calculation.
04-06-2016, 06:23 PM | #7 | |
Rep 29
"the 20x10 will be a 35et and the 20x11 will be a 30et", the Hamann suspension lowers the car 45mm front and 30m in the rear. I wouldn't recommend spacers with this set up as you will be almost flush with the fender without them." |
04-06-2016, 07:18 PM | #8 | |
7266
Rep 6,561
i have used spacers on many different vehicles that i did not have custom wheels for and it works out well if you just take the time to do the math and then get the appropriate alignment afterwards. many say you don't have to align after spacers alone but i am stickler for details and considering you're going to lower as well i would highly recommend an alignment about a week after you install the springs and spacers. |
04-07-2016, 09:27 AM | #9 |
Rep 119
i have 20mm all around on my 20" 469 and i highly recommend at least 20mm, many people on the forums saying 20mm is too far but it looks great, with even a possibility to do 25 in rear. obviously its all personal preference, just my opinion, hope this helps
04-07-2016, 09:54 AM | #11 |
Rep 1,547
If I can chime in, H&R 15mm front and 20mm rear with my OE 469M's. I've got the ACS springs/links as well, and am very happy with the stance both height and width wise. To me, this is how it should ship from factory. That said, being a 'wee bit' lower would be nice. Worst case, you mount the wheels and want them spaced out a little, buy spacers...very easy solution.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
04-07-2016, 10:37 AM | #12 | ||
Rep 18,715
04-09-2016, 03:37 PM | #13 |
Rep 89
this is H&R spring kit for air leveling rear. 5mm spacers in front 15mm in the rear (per Ben's suggestion).
you are going to want these, trust me: https://www.rallysportdirect.com/par...FdNahgode7oKuw Last edited by mdallas; 04-09-2016 at 03:45 PM.. |
04-09-2016, 04:18 PM | #14 |
Rep 18,715
mdallas , looks good.
Believe it or not, H&R start realizing the issue and the last batch that I have sold, came with the spring sleeve rubber.
04-11-2016, 11:38 PM | #15 |
Rep 29
I've seen a lot of complaints regarding spacers having a negative effect on the ride of the X5 and the awd, any experience with that? Thanks for all you input.
04-12-2016, 12:41 AM | #16 | |
Rep 18,715
Search my post regarding spacer. A lot of name brand TUV approved company and even OEM supplies spacer on their car. Simply put, wider stance, better traction and handling.
04-12-2016, 03:39 AM | #17 |
Mmmmm…
1150
Rep 2,426
Drives: F15
I'm wondering if the car will look any good without lowering springs, but with spacers...
04-12-2016, 07:33 AM | #18 | |
7266
Rep 6,561
how does a spacer improve traction? the height of the vehicle will not change but the wheel gap will look larger when the wheel is not as recessed from the factory.
04-12-2016, 09:03 AM | #19 | |
Rep 18,715
04-12-2016, 09:10 AM | #20 | |
Rep 18,715
It is acting similar as if you have wider wheels and tires setup. More tire contact toward outside of the car that will give you traction.
04-12-2016, 10:07 AM | #21 |
Rep 1,547
I threw my spacers on first (15mm front / 20mm rear) before I installed my ACS springs/links, as they arrived first. It looked 'ok' in my opinion, but looks much better once lowered.
