03-15-2016, 02:14 PM | #1 |
#dubspec
6336
Rep 5,201
Eibach springs/links installed
i have been debating installing any form of lowering on the f15 because i didnt want it to ruin the ride. although the car rides at a pretty acceptable height, another 1" would make it perfect imo. i chose the euro version Eibach spring with rear links. the font lowers about 1.3" and the rear you basically adjust wherever you like with the links. ride is great! most noticeable difference was driving it away after lowering. it felt tighter in any form of turning and slightly stiffer. after a week of driving, i cant remember it driving any different. winter is ending and our roads are full of random cracks and holes, and it drives very well regardless. no bounce, no jarring rebound.
car sits at 31.15" from ground to fender on oem 20" wheels. in the pics i test fit the 22" wheels to see how they look. very happy with the results
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
12
BobBeau173.50 Slickrick2211.00 BigHurmJr24.00 Mighteeminh1.50 daytonaviolet1250.00 MK2018230.50 MJRPA28.50 fsquared25.50 BlackBeans75.00 |
03-15-2016, 04:26 PM | #4 |
Rep 8,815
Looks awesome. BTW congrats on the upcoming toy!
I was wondering why you were hanging out on the other side of the forums Alan
03-15-2016, 04:33 PM | #5 |
#dubspec
6336
Rep 5,201
Thanks! It's going to be a little wait but i should have it by June.
03-15-2016, 05:14 PM | #6 |
Rep 815
Drives: G05 X5,G20 M340,Infiniti Q50RS
Drop looks good, perfect for the 22s. I cant find those 599 reps anywhere, i called the place you recommend, they told me they stop making them..
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
03-15-2016, 06:44 PM | #7 |
Rep 1,547
Looks great man. Well done.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
03-15-2016, 07:29 PM | #8 |
#dubspec
6336
Rep 5,201
03-15-2016, 10:00 PM | #10 |
Rep 7,063
I need to order some Eibach springs. Can't believe they aren't openly available in the states like the E70 springs
E90 Build Thread (SOLD) http://www.e90post.com/forums/showthread.php?t=809436
F15 Build Thread (SOLD) http://f15.bimmerpost.com/forums/sho....php?t=1064084 |
03-16-2016, 04:58 AM | #11 |
Rep 1,328
Looks great!
Are these essentially the same as the ACS Spring for he X5M? H&R is more aggressive but from reports it rides harder, while the ACS spring (which I believe is rebranded Eibach), rides like stock |
03-16-2016, 08:21 AM | #13 |
Rep 8,815
Where did you order the eibach springs from? Did you measure the drop before and after with the same wheels to see if it was lowered by the advertised amount?
03-16-2016, 09:11 AM | #14 |
Rep 525
im really digging those 22s and the x5 looks great!..... but i couldnt imagine the ride on 22s after the drop(Those tires look way to thin for any pothole)
lowered with H&R spring/link and 20s with Mich. PSS. its a perfect driving setup for every occasion. the 30mm spacers take it to another level, and are the only reason the 20s work.
03-16-2016, 10:22 AM | #16 | |
Rep 64
Do you have spacers front and back 30mm?
Thanks Quote:
03-16-2016, 11:16 AM | #17 |
#dubspec
6336
Rep 5,201
I only have 12.5mm rear spacers added. Could use 5mm up front but not nessacary
03-16-2016, 11:17 AM | #18 |
#dubspec
6336
Rep 5,201
Baan velgen. Great price too. Drop is pretty much bang on as advertised.
03-16-2016, 11:18 AM | #19 |
#dubspec
6336
Rep 5,201
They are half the cost of the overpriced ac schnitzer springs.
03-16-2016, 02:15 PM | #20 |
Rep 525
yes 30mm all four corners. i wanted to keep the ?geometry ratios? the same for the stance, but it might sit a tad wider then it needs to in the front....25 all around is probably best, but i believe the reason i did it was because of the DRA spacers options and sizes. i wanted stock bolt sizes and no extended lugs. i think 25 mm spacer have extended lugs only and to get DRA which bolt to the hub then you bolt the wheel on, you need to jump up to 30mm
03-16-2016, 02:20 PM | #21 |
Rep 89
that is outstanding!!!
I'm having the H&R Kit installed tomorrow (for 2VM). I also got the 5mm (front) and 15mm (rear) spacers. Will put those on in a few weeks when the 20" 451 Y spokes go back on. |
03-16-2016, 09:06 PM | #22 |
Rep 710
That is a very cheap price. Approx $50-ish per corner... Too bad they're progressive. How many miles on your car when installed?
Sold: 2014 X5 xDrive35d MSport
