BMW X5 and X6 Forum 2014-Current
      03-09-2016, 12:20 PM   #1
stewy604
stewy604's Avatar
290
Drives: 2014 BMW X5 xDrive 35d M Sport
Wheels corroding - mainly around center caps
Hey Guys,
I'm in the midst of chasing BMW on warranty for corrosion on my 469M's. I haven't had the chance to upload photos, but just wondering if any of you have or are experiencing the same issue? The clear coat around the center caps is corroding on all four wheels, some worse than others. I'll keep you posted on the response from BMW Canada on my warranty claim. Definitely frustrating that I'm seeing this happen, the vehicle isn't even 2 years old yet.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey
2007 Suzuki GSX-R 750
      03-09-2016, 12:45 PM   #2
MajorBulldog
Drives: 2016 BMW x35i X5 Luxury Line
The wife and I bought 2016 models in late Dec. 2015. Both showed a rust-like ring around the center caps within two weeks from taking delivery (both cars, so all eight wheels). It wipes off easily, but seems to reappear a day or so after a trip to the touchless wash. My theory is that the jets from the wash are forcing water around the caps (they aren't sealed very well) which causes a little corrosion behind them, and the rusty water eventually drains (or spins) out. I assume that BMW knows about this and all they would do would be to wipe it off. To truly fix, they would need to use caps that completely sealed, or coat the rim behind the cap so that it never rusts.
Anyone have any experience with a dealership addressing this? If so, how did they address it?
      03-09-2016, 01:38 PM   #3
Stinkyxy
Drives: X5
Might be the same issue people have experience with calipers rusting. There must be some steel behind the wheel that is rusting.
      03-09-2016, 02:28 PM   #4
spike5150
Drives: 2020 X5 M50i
There is a copper colored anti-seize compound on the wheel hubs - could it be that?
      03-09-2016, 03:52 PM   #5
stewy604
stewy604's Avatar
290
This is definitely not rust, or marks that will wipe or polish away. The issue noted above could be the hubs themselves, as they are raw/un-coated steel and are always 'rusty'. Image hosting sites are blocked through our firewall at work...otherwise I'd share photos.
      03-09-2016, 05:12 PM   #6
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
Drives: Audi BMW Ferrari LR MB
common. not covered under warranty. it is from the hubs and works it's way out. eventually the chrome finish around your center cap will start pitting and peeling.
      03-09-2016, 05:24 PM   #7
turboawd
Drives: 2015 X5 35i
sometime the tire change places use an improper sized cone to clamp the rim for balancing, and it ends up pushing against the lip of the bore where the cap sits. this can scratch or damage the wheel coating, which leads to corrosion.
      03-09-2016, 08:52 PM   #8
MajorBulldog
That's exactly what ours look like (though ours aren't quiet that bad). If we could seal around the caps, I think it would stop.
      03-09-2016, 11:27 PM   #9
turboawd
Drives: 2015 X5 35i
pop the cap off and spray some wd40 or other oil in there.
      03-10-2016, 11:07 AM   #10
stewy604
stewy604's Avatar
290
Got a meeting set for later this morning with my SA and his Service Manager. Stay tuned.
      03-10-2016, 01:01 PM   #11
Mexecutioner
Drives: 2015 X5 xDrive35i
Good luck, I hope this gets resolved. It may be "common" but definitely not OK.
      03-10-2016, 04:15 PM   #12
stewy604
stewy604's Avatar
290
Updates...just got back from my meeting at my dealer. They've documented everything with photos (of their own) and will be submitting for warranty replacement. I should know within a few days.
      03-10-2016, 06:24 PM   #13
taken
Drives: 2016 X5 xDrive50i
There is a product called "Fluid Film" that prevents corrosion on all types of metal. If/when you get your situation settled, coat the center bore and backside of the center cap with Fluid Film before while reinstalling. It should prevent future rust seepage from the rotors/hubs through that area and keep your issue from returning. Reapply as necessary...
Regards, Rodney
2016 X5 xDrive50i
      03-11-2016, 09:56 AM   #14
stewy604
stewy604's Avatar
290
Nice man, thanks for the tip! We actually use that product as a protectant on our CAT equipment before we ship from factory.
      03-11-2016, 10:19 AM   #15
taken
Exactly. Fluid Film is great for anything that can rust or corrode. A lot of guys on the Ford forums I'm on for my truck keep much of their undercarriage coated in it.
Regards, Rodney
2016 X5 xDrive50i
      05-02-2016, 10:48 AM   #16
stewy604
stewy604's Avatar
290
Updates guys. Wheels will be back from local re-finisher today, completely refinished under warranty. I did new rubber at the same time, went with the Conti DWS06. Keep you posted on my feedback with the tires.
      05-02-2016, 12:15 PM   #17
IvanLZ
IvanLZ's Avatar
Drives: 2015 X5 35i
I would like to know more about those tires. Any change in driving and comfort?
      05-02-2016, 12:50 PM   #18
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
i had all 4 wheels replace under warranty on my 15 x3 msport, more liking pitting around emblem.
      05-03-2016, 06:51 PM   #19
stewy604
stewy604's Avatar
290
Tires ride and feel great, slightly softer than the RFT's...but no 'squishy' by any means. Very happy so far. I've been driving fairly spirited, and they perform well.
Same idea on mine, like a white clouding / pitting, from the center outwards. I pushed for full replacement, but they wouldn't go for it.
      05-04-2016, 07:15 AM   #20
IvanLZ
IvanLZ's Avatar
Drives: 2015 X5 35i
Thanks for the info! For sure getting those tires after i finish my p zero's
      05-04-2016, 09:39 AM   #21
stewy604
stewy604's Avatar
290
^^^ That won't take long. Mine lasted just over a year.
      05-04-2016, 01:40 PM   #22
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
this was one of the wheels on my 2015 x3 msport, had the same issue on the rest of the wheels.
last year when i address the issue to 2 service advisors, they walked outside and took pictures of the wheels. It took probably a month and all 4 wheels were replace under warranty.
xbimmers
