11-16-2015, 10:40 PM | #1 |
Rep 195
engine oil consumption level
3 months ago. I did the rod bearing replacement.
also change the new engine oil. I have driven about 2000 miles after the replacement but the oil level is a little low. Is it normal? I do not drive hardly too much. |
11-18-2015, 04:21 PM | #3 |
Rep 734
To be honest, the oil level sensor is finicky. After you changed the oil was it at Max? Even if it is, it could've been an incorrect reading. Usually the sensor takes day or two, or for some almost up to a week for it to accurately show oil level. If your oil level wasn't at max, coupled with 2000miles of driving, i can see that it is "normal."
With the S65, many people say their car dont burn a drop of oil, others add a quart every 3-5k miles (ymmv). So I wouldn't say this is too bad. Check for leaks and make sure its not sipping somewhere. Cheers!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
11-18-2015, 10:20 PM | #4 |
Rep 195
11-18-2015, 10:21 PM | #6 | |
Rep 195
Yes . Last time I did the Rod bearing replacement and new engine oil.
It was at the Max . but now only about 2200 miles which is like I posted. Quote:
11-19-2015, 08:18 AM | #7 |
Rep 1,017
Drives: 2010 E92 M3 6MT
It could of been just on the edge on max when they replaced your oil after bearing swap, since it only reads in half quart increments it makes it difficult.
Add half a quart, that will prob bring you back up to normal levels. Then if it drops back down to oil low in 2k you will know for sure how much oil your burning and how fast. On side note I noticed no increase or decrease in oil consumption after bearing swap/and going FI.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
11-19-2015, 03:16 PM | #8 |
Rep 955
Assuming the gauge was accurate at MAX and is accurate now, that still doesn't look too bad. 2200 miles to get to here. I would bet that you will hit 4000 before she asks for another liter. At which point I would add 500ml and see where it ends up in a week. So I'd say your engine is burning 1L / 4000 miles roughly. Which is well within the range. From what I recall the manual even states so... If not the manual there is a BMW TSB (S65 specific BTW) out on the very same subject...
My understanding is that between "min" and "max" is a little less then one liter. Some posts on here say 1L, but I call it 800ml to be safe and not overfill. So if I want it to move up a quarter. I add 200-ish ml and leave it alone. Even if it doesn't register for a day or two. |
11-19-2015, 09:36 PM | #9 | |
Rep 195
sorry, sir... I am not American.
Something you said I cna not understand. forgive my poor English. You mean that will not increase or decrease in oil consumption even thought I replace the rod bearing? So, My situation is not normal? Quote:
11-19-2015, 09:43 PM | #10 | |
Rep 195
so. my car is burning about 1L / 4000 miles .
It is the normal range? right? If my car have the warning that want me to add 1QT or 1L. Someone told me add 1/4 of the bottle. Someone told me add 1/2 of the bottle. so...which one is oK? I know that do not add a full bottle of oil, that will overfill. I am just waiting for it tells me to add oil. Quote:
11-19-2015, 09:47 PM | #11 |
Rep 195
and I bought the Castrol TWS 10W60 .
I notice there are many kind of Castrol TWS with similar names and bottles. Is it OK if I add this one which I bought? |
11-20-2015, 12:17 AM | #12 |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
When it asks for more give a half. I've given it the whole bottle before and it complains that it's too full. I don't trust this meter entirely, I've had experiences where I have just gotten an oil change and it reads at the halfway mark. 60 miles later it will tell me it's at minimum. I add half a liter and it still complains no matter how many times I reset it. Next day after engine is cold it will say halfway again. Frustrating.
11-20-2015, 01:08 AM | #13 | |
Rep 195
I see. so , the oil which i posted is ok to add. right?
11-20-2015, 08:00 AM | #14 |
Rep 1,320
Add half the bottle, drive around a little bit (5-10 miles), see if the sensor changes! If not, add the other half of the bottle, and repeat.
I don't think it's anything to be worried of yet. Add it to get back to a desired level and if the oil level drops again in a short amount of miles, then I would consider taking some action. |
11-20-2015, 08:39 AM | #15 | |
Rep 1,611
I personally would suggest you, getting an OBD 2 reader dongle. I use Carly ( former BMWhat ) made a vid, check my sig. Because we here found out, that it even read's out our engine's oil level value. What I like to tell you by that is, it's more accurate then just your car- oil- level indicator as it show's you an value! Now if you refill, the value immediately change's even before you built-in car-indicator move's. It's very precise and accurate. If the value doesn't change...your oil sensor went down south. That way you easely can rule out an faulty oil sensor or the high oil consumption. Here's how it look's like using the OBD 2 dongle from Carly. |
11-20-2015, 08:55 AM | #16 | |
Rep 1,320
11-20-2015, 05:25 PM | #18 | |
Rep 24,669
Strange...Don't see your pic , that's why I will post pics how your bottle should look like . Pic 1 = Castrol TWS 10W60 Pic 2 = Castrol EDGE 10W60 Pic 3 = M Twin-Power/Turbo 10W60 made by Shell is what most BMW/Dealers use for the moment and is actually only upgrated by brand marketing . One of those 3 bottles and your good to run . Hope this will help .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
11-20-2015, 07:31 PM | #19 | |
Rep 195
yeah. I will wait for it until it tells me to add. thank you man~~
11-20-2015, 07:38 PM | #20 | |
Rep 195
I have the OBD 2 code reader but I dont know if it can read the oil level or not. forgive my English is not good. I dont dare to use the reader to test something which I dont understand.
11-20-2015, 07:40 PM | #21 | |
Rep 195
so, these 3 engine oil are fine to add.
the photo I showed you guys . Is it OK? I think it is the same oil... but I am not sure.... Quote:
11-20-2015, 08:03 PM | #22 |
Rep 24,669
The pic of your oil is not visible on here .
