M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      10-27-2015, 07:02 AM   #1
HappyMan
Drives: 2015 M5
WOW Look what engine oil we use.
I know its in Russian but you can understand the experiment going on to check wich oil is best. Apparently all of them are junk rubbish (Castrol, Shell etc..)
And look what Bardahl oil can do and how awesome it is. Just WOW
      10-27-2015, 04:09 PM   #2
supershaft
Drives: 992 GT3, Cayenne Turbo
skip to 6:30 to see the actual analysis.
      10-27-2015, 04:23 PM   #3
supershaft
okay so apparently a bunch of russians know better than a bunch of bmw engineers.
      10-27-2015, 04:38 PM   #4
EdM5
EdM5's Avatar
Netherlands
4066
Drives: G26 i4 M50 & E70 X5 Xdrive35d
Our German friends know a thing or two about building engines.
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d
      10-27-2015, 06:48 PM   #5
MyF15+F85
MyF15+F85's Avatar
50
Drives: 2015 F85 and 2015 F15
OIL !
OK
There are at least couple of things that should be noted, I'll just mention ONE.
If our engine components would be experiencing fiction as such, there we would be in no way be able to achieve 10,000 kms not to mention 100,000 kms
Our engines are design to work with oil pressure which produces oil film.
That in effect is the only thing between oil bearings , connecting rods, and pistons themselves. Oil is a vital lubricant ( medium ), that is pressurized, and holds everything in suspension.
In energy powerplants ( nuclear ) huge turbines ( 100 tons ) are literally suspended on just oil pressure alone, and they last years before any service to the bearings.
To sum it all up oil in our engines has to do two things mainly, one of them is to suspend crankshaft and then to ensure lubrication to the rest of the vital components. Taking away the heat is on of the additional duties assigned to oil.
Hopefully this will put some light on the subject.
For the time being please go about your normal routine, and change your regular ( synthetic ) oil, at your given intervals, you'll be just fine...
Cheers
      01-01-2016, 02:58 AM   #6
stalintom
Drives: working good
The engine oil really effective. There are many students facing problem with their academic papers. The term paper writing services helps them to complete their works.
m5post
