10-14-2015, 09:28 AM | #1 |
242
Rep 714
Liqui-Moly Blackstone Report
Second report I've done, lead went up to 11ppm on LM 10w-60 GT1. Not sure how concerned I should be with a rise in lead count. Wouldn't think 11ppm is something to concern myself with, at least not until my next change and report.
Have others seen a rise in lead ppm with the switch from Castrol to LM? See attached.
Current: 2009 Alpine White/Black e90 m3
Past: 2008 Interlagos/Black e92 m3 |
10-19-2015, 12:07 PM | #3 |
242
Rep 714
Didn't think the report was bad at all. Why would you say that?
I think it will be a little bit better determination based on my next report. 11pm lead and 2ppm copper is fairly low.
10-19-2015, 12:24 PM | #4 |
Rep 5,508
I would not go with LM 10w60... it is a lot thicker than BMW 10w60. It'll only make bearing clearance issues worse.
Stick with the OEM 10w60 or go with something lighter.
Auto Detailing Enthusiast!
10-19-2015, 01:27 PM | #5 |
Rep 1,320
OP I've been (as well as many others here..) on LM 10-60 for a long time no and no issues thus far. It's also been proven that these reports aren't definitive! So yes, while it is possible that your bearings are on its way out, there's no real way of knowing!
But nonetheless, good looking report! |
10-19-2015, 01:59 PM | #6 |
242
Rep 714
Got another 2k miles on this change. Have already had to add a bottle of Twin Power Turbo within 4k miles (since last change).
So I'm running a slight mixture of TPT (OEM) and LM.
10-25-2015, 07:41 PM | #7 |
Rep 12,736
how is one of two oils with the same weight rating "a lot thicker" than the other?
Instagram; @roastbeefmike
