ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      02-21-2008, 02:40 PM   #1
Gabri343
Italy
11
Drives: Z4 M Roadster - ex M3 E46
Help me! Information wheels Z4 M
I have a problem, BBS CH
http://www.tirerack.com/images/wheel...s_ch_ci3_l.jpg
8.5x19 Offset: 35mm
19x10 Offset: 20mm
Are they ok for Z4 M?
Thanks!
      02-22-2008, 09:51 AM   #2
Hawkeye
Hawkeye's Avatar
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
You should post in the Wheels/Tires forum... I am sure it would get more replies... and you would also be following forum guidelines
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      03-14-2008, 05:49 PM   #3
pmeloche
pmeloche's Avatar
Drives: 2013 F25 X3 xDrive35i
If my calculations are correct the front wheels are within 1mm of the OEM wheels' fitment while the rear wheels are less than 3mm from the OEM wheels' fitment so you should be ok.
OEM: Front: 8*25.4/2 + 42 = 143,6mm
Rear: 9*25.4/2 + 30 = 144,3mm
Your wheels: Front: 8.5*25.4/2 + 35 = 143,0mm
Rear: 10*25.4/2 + 20 = 147mm
Cheers.
Patrice
2013 F25 X3 xDrive35i Vermillion Red
      04-09-2008, 10:28 AM   #4
3002 tii
3002 tii's Avatar
2282
Drives: Z4 M, X5, GX460
i've been sweating ch's in 19 for a long time, but way too expensive. and nobody has a used set =T
Follow for latest mods
      04-09-2008, 11:08 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Cheers.
Sorry that calc doesn't work......
Use this calculator to estimate effects of offsets & wheel size.
10" ET20 are VERY aggressive & will likely rub
A 10" et20 wheel will EXTEND out an extra 34mm!!!
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      04-12-2008, 04:27 PM   #6
Dieselino
Dieselino's Avatar
47
Drives: 03 LSB M3 06 M coupe 08 M3 SG
It would extend the rears 23mm not 34mm. Not sure where that calculation came from. the stock Z4M's rear wheel is 9 inches wide with a 30mm Offset. The fronts would be fine they would extend out 13mm. But 23mm further out in the rear is too much. The wheel will sit further out then the body.
      06-18-2008, 04:32 AM   #7
gnx
Όλα ρόδες
gnx's Avatar
760
8.5x19 Offset: 35mm
19x10 Offset: 20mm
Thanks!
Whatever happened with the CHs, Gabri? Did you put them on?
      06-20-2008, 04:03 PM   #8
M2audioman
Drives: 2018 M2
I found this pic on the net. Looks like the wheels fit fine and they look great!
zpost
