08-28-2015, 06:41 PM | #1 |
Rep 12,728
Got a great report, and I couldn't be happier.
My car had about 33,000 miles on it at the time. This report was with oil that had about 10,000 miles and one track day on it. My car now has 43,000 miles on it, and coincidentally went out of warranty today (ran out of time). I let the car idle for about 1-2 minutes, then I drive it gently until the oil is at or close to 210*F. My car typically runs at about a needle's width below the 210 mark unless its a hot day and I'm running the A/C. I definitely don't beat on the car until I have been driving the car for a while and everything is warmed up. I'm also one of those people that only used Chevron 91 gas. Photobucket sucks these days, but this is what I got.
Instagram; @roastbeefmike
08-28-2015, 11:55 PM | #2 |
Rep 1,755
0 Lead very nice but it is 2011 which doesn't show lead metal
BTW, are you changing oil every 10k miles? I have been told by some that I don't need to change it every 5k or 7.5k if I don't track the car and this type of oil can be good upto 10k |
08-29-2015, 12:23 AM | #3 | |
Rep 12,728
i change my oil about every 7.5-8k. i was under the factory maintenance until it expired and payed $200 for oil changes between what the dealership would perform (i just didn't reset the oil timer). my car does burn oil, and i could attribute that to road trips where i was driving about 400 miles at 80-85mph and track days. i think 15k intervals are somewhat asking a lot of the oil in a performance engine. 10k is comfortable, and 7.5 is where i would like to be. i have never had any concerns with noises, etc. with this car and i'm going to continue to track and keep up the maintenance and care habits i have developed. it isn't my daily driver anymore, but i do intend to keep it forever.
08-29-2015, 08:58 AM | #4 | |
Rep 1,755
08-29-2015, 10:16 AM | #5 |
Stop the hate, get a V8
3850
Rep 8,625
Looks fine to me. Pay for TBN and TAN next time so you can establish a good change interval.
BTW, no need to let the car idle for 1-2 minutes, it won't do any good (actually a bad idea to do this habitually).
Past: 2011.5 M3 sedan ZCP |
08-29-2015, 12:39 PM | #6 | ||
Rep 12,728
i know the two minute idle has been debated a bit, sometimes it is a little less. i'm going to keep doing what i'm doing... i'm a little ocd with stuff like this.
08-29-2015, 01:21 PM | #7 | |
3850
Rep 8,625
TBN = total base number, which is a measure of reserve alkalinity. In other words, how well can it neutralize acids. Higher = better. As the oil wears out, the TBN will start to fall. TAN = total acid number, which is a measure of the oil's acidity. As the oil is in use longer, it will grow more acidic. The current way of thinking is that you need to change it when TBN and TAN numbers are pretty close (ideally the TBN should be a little bit higher, but there's no way to tell until you pull the oil). These are the better ways to determine change intervals. Even though particulate matter might be fairly low, if the oil has run out of that reserve alkalinity, it needs to be changed. What I did when I first got the car was to pull a sample of the oil at about 5,000 miles and send it in for analysis. From that, I was able to tell that 7,500 was a very safe change interval (for my exact motor and driving style) and that I could've gone even longer. I suggest you do the same. A small hand pump is about $20, and the analysis with TBN and TAN is about $40. If it lets you stretch the change interval out, that saves you money. As far as prolonged idling, do you understand that it is actually worse to do that? When the car is cold, it is running very rich and contaminating the oil with fuel. You are basically wearing the oil out faster (the above reserve alkalinity will have to try and fight the gasoline) and thinning the oil out. You are also forcing the motor to pump extremely thick oil for longer than it has to. If you look at an oil analysis for a car in the winter, and then look at the analysis for the same car in the summer, you will see the winter oil being thinner and needing to be changed faster. My advice is to just start the car, wait a few seconds, and keep engine load low until the oil has heated up a bit.
08-31-2015, 11:19 AM | #8 |
Rep 1,792
I say bravo, here's why: your M3 obviously has the newer non-lead bearings, and from my observation, non-lead bearings M3 UOAs typically show zero lead of course, but a few ppm of tin/nickel would show up in the report. Yours show zero, so I say keep whatever you're doing.
09-28-2015, 06:35 PM | #9 | |
Rep 658
I agree if you're going to drive it right away, low RPM and low load is crucial to not hurt the engine when cold, especially when using thick oil; however I don't know what the difference is between idling/cycling the rpm while stationary vs. driving it slowly is.... |
09-28-2015, 07:51 PM | #10 | |
3850
Rep 8,625
I'd say their use case for motor oil and engine longevity is vastly different than a street car's. Apples-to-oranges.
09-29-2015, 03:59 PM | #13 | |
Rep 12,728
The only time she has asked for oil is usually long road trips at about 85 mph for an extended period of time.
10-01-2015, 12:40 AM | #14 | |||
Rep 9
