08-22-2015, 02:12 PM | #1 |
Rep 1,632
From castrol tws to liqui moly??? Who made the switch???
Im about to switch from castrol to liqui moly oil as of my next oil change (150$ saving in total).
Who here made the switch?? Is it gonna potentially affect my engine if for 69k miles car has been oiled with castrol?? Thanks Mike |
08-22-2015, 03:38 PM | #2 |
Rep 999
You should do some search on here!
Plenty have and no issues. I'm on M1 0-40 and supercharged
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
08-22-2015, 06:50 PM | #4 |
Rep 1,632
08-23-2015, 08:22 PM | #6 |
Rep 1,632
08-23-2015, 10:40 PM | #7 |
Rep 2,672
I'm about to change my oil as well and noticed ECS Tuning has decent pricing on a Castrol TWS oil change kit. Does anyone know who sells a kit with Liqui Moly for comparison?
08-24-2015, 04:48 PM | #8 | |
Rep 734
As mentioned though, do a search on the forum. Many here prefer and have switched to M1 0w40. Liqui Moly 10w60 seems to be a quality oil but is even heavier/thicker than the Castrol eventhough they are rated at the same weigh (10w60). In Ontario where you are in the summer time i don't see a problem, but when it starts to get cold tbh i think the M1 0w40 will server better. Also depends on your driving habits and conditions, and whether or not you do some HPDE/ autox etc. I do 100% M1 0w40 in the colder months, and switch to mix of M1 0w40 with TWS 10w60 (around 6L M1 and rest Castrol)in the summer months here in Vancouver. Cheers!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
08-24-2015, 04:50 PM | #9 |
Rep 734
Nope, never came across a Liqui Moly kit, but best probably is to source the oil and buy filters in bulk (ebay or some online merchants), you will save money for sure. Cheers!
08-24-2015, 07:47 PM | #10 | |
Rep 1,632
car will be stored for the winter so i might try the M1 0w40 on my next oil change !! My father did the switch last month on his e90m3 and he said its all good |
08-25-2015, 10:34 AM | #12 | |
Stop the hate, get a V8
3850
Rep 8,625
It's of equivalent quality (from BMW's perspective) to the Castrol TWS, hence the OEM certification. You can use it with confidence. BMW has changed suppliers from Castrol to Shell/Pennzoil.
Past: 2011.5 M3 sedan ZCP |
08-25-2015, 11:22 AM | #13 |
Captain Fatbelly
1423
Rep 1,994
Switching to an even thicker oil isn't a great idea IMO. Its not talked about a lot on here but 5w40 is a good alternative.
2013 c63 Amg coupe p31, v7 tune, plm headers, armytrix downpipes, EflexFuel
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. |
08-25-2015, 01:14 PM | #14 | |
3850
Rep 8,625
IIRC the Shell (Pennzoil) oil has HTHSV of 5.4, which is basically the same as TWS.
08-25-2015, 04:38 PM | #15 |
Captain Fatbelly
1423
Rep 1,994
I was talking about LM. Looks like it is almost 10% thicker than tws...
08-25-2015, 04:41 PM | #16 | |
3850
Rep 8,625
Is the HTHSV being published now? A lot of manufacturers don't put that on the spec sheet, but you can sometimes get it by asking. I bet it's pretty close to TWS's 5.4.
08-25-2015, 04:58 PM | #17 |
Captain Fatbelly
1423
Rep 1,994
I was just going by the viscosity index and pour point. They look pretty comparable otherwise.
08-25-2015, 05:11 PM | #18 | |
3850
Rep 8,625
Those are not good indicators of an oil's operational viscosity. Pour point is largely worthless -- not even sure why it's published. CCS or MRV are far better because they measure pumpability at low temperatures. VI is a decent indicator of the base oil's quality and sometimes its resistance to shearing.
08-25-2015, 06:23 PM | #19 |
Captain Fatbelly
1423
Rep 1,994
I always thought the higher the vi, the less the shear, leading me to believe the tws shears down more than the LM. Is that not how it works?
08-25-2015, 06:39 PM | #20 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
If you are going to blend oils to alter viscosity, it would be more predictable to stay within the same brand and type of oil. Combining different base stocks with different viscosity stabilizers from completely different sources is a bit of a crap shoot. I wouldn't do it, but that's just me. If you want a slightly heavier version of Mobil 1 0W-40, you could blend in a 3-4 quarts of the same basic version of Mobil 1 in a 15W-50. The final results still aren't guaranteed, but would be closer to expected than mixing Mobil 1 and Castrol, which, I am pretty sure neither manufacturer would recommend.
08-25-2015, 06:48 PM | #21 | |
3850
Rep 8,625
That is not how it works. Higher VI can sometimes be a sign of VIIs (viscosity index improvers), which may or may not be able to withstand sustained punishment. It really depends on the formulation. Some oils have naturally high VIs, and those tend to be more stable. TWS uses more group V oils which typically have a naturally high VI. It is difficult to tell if an oil will be shear stable just by looking at the VI. One theory that's been thrown around on BITOG is to approximate it with this formula: Dynamic viscosity @ 150 C ------------------------------ HTHSV (@ 150 C) Just as an example, Motul 300V 0w40 has a calculated "shear resistance" of 0.8795, but Pennzoil Ultra 0w40 only has a VI of 0.7173 despite having the exact same VI of 186! If you're curious, the TWS shear resistance works out to about 0.8094. Not exactly the champion in this area, but still a very respectable number given its huge 10w60 viscosity spread. Many 0w50s I've looked at only offer shear resistance in the low 0.7x range.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 08-25-2015 at 07:05 PM.. |
08-25-2015, 06:52 PM | #22 | |
3850
Rep 8,625
I agree that if you're going to mix, you should stay within the same manufacturer (and within the same "lineup" if possible). Red Line even says this on their website. However, API certification means that it must be miscible with other API certified oils. Is it optimal? No. You can get additive pack clash if you start doing really funky stuff with drastically different types of oils. If you're going to mix two LL-01 certified oils together, for example, I don't think it would be a huge deal since they're already very similar.
