07-06-2015, 09:17 AM | #1 |
Rep 307
Cheapest place to get a Steering Angle Sensor?
I starting getting EDC failures every couple of days, I could clear the code and it would be fine for a day or two. Now it EDC error is on all the time. Pulling the codes shows a Steering Angle Sensor exceeded maximum value or something like that. If the steering angle sensor were bad wouldn't the stability control stuff be malfunctioning too?
So I figure I should look into replacing the steering angle sensor, where do you guys get them? I'll just install it myself and have the local shop code it to the car. I tried to clean it out as per another thread I saw on here, but it wasn't dirty at all, looked fairly new. But the error code says steering angle sensor so I guess I gotta believe that.. |
07-06-2015, 09:28 AM | #2 |
Rep 183
I usually have good luck with car-part.com. You have to know exactly what you are trying to find.
08 E90 M3 - 6MT, Interlagos Blue, no moonroof, tech package, carbon trim, silver interior.
07-06-2015, 09:45 AM | #3 |
Rep 307
07-06-2015, 10:26 AM | #4 |
Rep 183
Looks like it's integrated with the stalks and it is interchangeable depending on which ones you need.
http://www.realoem.com/bmw/enUS/show...diagId=61_3088
07-06-2015, 10:32 AM | #5 | |
Rep 307
07-08-2015, 09:29 AM | #7 |
Rep 307
07-10-2015, 07:53 AM | #8 |
Rep 307
Re-zeroing the steering angle sensor didn't work unfortunately. So since the encoder wheel and sensor are super clean its got to be the circuit board. I'm going to try re-flowing some of the solder joints.
Why does this part have to be $600? |
07-10-2015, 02:08 PM | #9 |
Rep 183
07-10-2015, 04:28 PM | #10 |
Rep 307
07-11-2015, 12:41 AM | #11 | |
BimmerPost Supporting Vendor
163
Rep 318
