07-05-2015, 01:30 PM | #1 |
Rep 65
Start-Up Question - E90 M3
I've only had the car a few days, but had a quick question for the group.
On my 2nd day of ownership I pulled the car into my driveway (its awfully steep) and parked to wash/wax. Usually after I am done with detailing, I will back any of my cars out without the motor having turned over (in case the oil is tilted too far from the pickup by the driveway slope). With my E90, I did this same thing, and when I was back on the level street for a few seconds, I went ahead and fired it up. Initially I got the "car up on the lift" service image in the center display with the exclamation point. However no service codes appeared. Now 2 days later when I start the car, I get a brief picture of a car (not on the lift...just the car), with the chime and exclamation point which go away after 2-3 seconds, however there are no service needed indicators in the I-Drive or shown when cycling through the stalk. The one "weird" thing is that the car seems to take awhile to calculate the oil level each time I start it (even if I simply run into a store for a minute and come back out) where it first shows unable to read with no oil level shown, then thinks about it, then finally displays dead in the middle of the gauge. Is the chime and exclamation point upon startup (and quickly going away) normal? Thanks! |
07-05-2015, 02:05 PM | #2 |
997.1TT
1003
Rep 1,672
When you start the car up, is the door open?
Current: 2007 Porsche 911 Turbo Former: ESS Supercharged ///M3 Interlagos Blue ZCP Subscribe to YouTube: https://www.youtube.com/c/Rat3dM Follow me on Instagram: https://www.instagram.com/rat3d_m/ |
07-05-2015, 04:52 PM | #4 |
Rep 2,030
Drives: G80 M3 Competition
Not sure why you saw the car on lift... But I do recall seeing the car picture briefly every time I start up, and it shows the miles till next service underneath. I also get the exclamation point briefly, but like posted above, I think that's for the seat belt.
07-05-2015, 09:17 PM | #5 | |
Rep 65
Not sure. I'll need to be more conscious of whether I am pushing the button prior to shutting the door.
After washing the car along with the car on the lift, it also reset my clock? A little weird, but I cannot imagine the water from my hose was anywhere near powerful enough (and definitely wasn't sprayed in the engine bay) to have any sort of impact... |
07-05-2015, 09:28 PM | #6 |
Rep 855
If you're opening and closing the doors a lot, the car never goes into sleep mode. I am almost certain you got an "Increased battery discharge" warning at the time you were detailing. Happens if you're playing with your car for a long time..
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
07-05-2015, 09:45 PM | #7 |
Rep 1,974
Yea the car appearing in the beginning is normal. Oil level taking a while to show up is also normal. Like jdamore said, car on the lift probably was a battery warning which could indicate it will be time to get a new one soon.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
07-06-2015, 04:46 AM | #8 |
Rep 2,442
Drives: 2022 M3 6MT
If it is a battery, a trickle charger will help a great deal when not in use. I used to get that discharge warning all the time, but with the charger, it hasn't appeared in over a year.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
07-06-2015, 04:20 PM | #9 |
Rep 65
I tried the "key in" but not turned over check of the message center and nothing appeared to be stored.
Door is also closed, so the chime is definitely related to the exclamation point which goes away, I would imagine. When you guys first start your cars and cycle to the oil gauge, does it always read as nothing on the gauge with those lines? I thought it would first just go to the last read oil reading while re-reading upon startup. |
