06-17-2015, 03:42 PM | #1 |
Rep 34
Yet Another 08 Rod Bearing Replacement
Brief history on the car......I bought it from an independent used car lot with 43k miles. Extremely clean inside and out and a clean car fax with two previous owners.
Going into this (my first M car purchase) i was well aware of the rod bearing problems and was prepared to do the maintenance. Although i obvioulsy was hopiing my oil analysis was going to tell me it wasnt needed....lol I got the car and put about 1500 miles on it and then took an oil sample. Ive attached the sample as well as a few photos of the bearings worn completely down to the copper..... |
06-17-2015, 04:04 PM | #2 |
Rep 368
thanks for posting that. It's good to see a Blackstone report correlated with bearing condition.
06-17-2015, 07:02 PM | #4 |
Rep 362
This.
06-17-2015, 07:15 PM | #6 |
Rep 456
Drives: 2008 E92 M3
So keep an eye out for copper AND lead on oil analysis, thanks.
2008 Sparkling Graphite E92 M3 DCT SOLD
www.flatoutmotorsports.us (We host track events in the Southeast) |
06-17-2015, 07:34 PM | #7 |
Rep 24,678
No need to post high reso. pics , because they look like crap .
Good from OP for replacing the bearings , because it was about time . Thanks for sharing the pics..
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
06-18-2015, 07:56 AM | #9 |
Rep 10,616
We have yet to see a set come out that looks fine. Mine looked better than yours and I had 50% more miles -- 61k, but they still showed inconsistent wear and copper along some bearing edges.
What I don't know and no one has ever elaborated on, is how much longer bearings that look like the OP's would have gone if left alone. 10k? 50k? 100k? 150k |
06-18-2015, 08:47 AM | #10 | |
Rep 34
After the engine was warm or driven for a few minutes the noise was gone on re-starts. This along with the oil report had me convinced that i had gained some excess bearing clearance. Regarding the question as to how much longer they would have lasted..... I think that is pretty hard to predict......but what i will say is that looking at the condition of these in person.....If i would have known how bad they were i wouldn not have driven it at all. The photos arent that great but every single upper half bearing had worn through the babbit some. Three of them were showing copper...not just on the edges but in the center as well. |
06-18-2015, 10:15 AM | #11 |
Rep 2,301
Are these bearings starting to wear? Yes. Are they done? NO. They are still thick. Worn bearings that make noise are very thin, almost like paper, and they slide in and out of the rod making the infamous ticking noises people hear. OP what did you replace them with? Clevite oem, or Clevite coated aftermarket?
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
NoHedge67.50 |
06-18-2015, 11:05 AM | #12 | |
Rep 5,506
Auto Detailing Enthusiast!
06-18-2015, 12:05 PM | #13 |
Rep 2,301
You're right. We've seen 2 engines go, with coated bearings after 5K miles.
'07 335I w/ Mods
06-18-2015, 12:15 PM | #14 |
Rep 3,988
While they do display some wear, they do not look that bad. There have been much worst.
Maybe the pictures aren't clear enough for me, but i'm not seeing any copper.
06-18-2015, 12:36 PM | #15 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Think its just the camera, that 2nd shade of wear in the silver should be bright copper. These picks only showing it a slightly darker shade of silver which is not what the next layer is.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
06-18-2015, 12:49 PM | #16 |
Rep 5,506
The brown/orange color on the bearings is the copper showing.
06-18-2015, 02:36 PM | #17 |
Rep 10,616
06-18-2015, 02:52 PM | #18 | |
Rep 34
The bearing shell with babbit is rougly .078" thick......a piece of notebook paper is about .003" thick. The bearing shell ID is about 2.093", I can guarantee you that if you had .020" clearance between the rod bearing ID and the crank journal OD it would be knocking so loud you would be scared to run it...... I am not sure how much experience you guys have with hydro-dynamic bearing design but the condition of these bearings would be totally unacceptable in any piece of rotating equipment such as.....internal combustion engines, gas turbines, electric motors, steam turbines etc...... I dont know what the stock clearance was but i see this problem as mostly being caused by the babbit formula..... The original intent of my post was just to make people aware...again....that there is a genuine concern/problem with the rod bearings in these engines. Also i want to say thank you to all who contribute here......without reading you guys post i would have never been aware of this problem and destroyed this engine |
06-18-2015, 04:14 PM | #19 | |
Rep 2,301
1. combine new rod bearings with stretched out old rods 2. leave your main bearings untouched (main and rod bearing wear mirror each other). 3. Leave yourself to the mercy of your installation quality. i.e at least 30K miles, to know whether you're clear of any issues, like incorrect torquing specifications, or dirt under the bearings, just to name a few.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N Last edited by Killerfish2012; 06-18-2015 at 06:31 PM.. |
06-18-2015, 04:30 PM | #20 | |
Rep 2,664
Drives: Goggomobil
True, BL report is showing exaggerated Lead reading, and cause for concern. But just looking at the bearings alone don't say much. So you took a precautionary measure. Only a handful of people, paranoid about the BF issue do it. Others get on with life ...
F86 X6///
06-18-2015, 05:09 PM | #21 |
Rep 656
Bearings look pretty bad... Upper halves are all damaged...
Detonation or cold start damage...? It gets pretty hot and cold in Texas, so take your pick... Congrats on catching it in time! Judging by the audible sounds of these engines upon first start up in the winter time, the oil is definitely too damn thick... Starting to think that these guys running 0w 40 are on to something... Why isn't there a good streetable 0w 60!! |
06-18-2015, 06:23 PM | #22 | |
Rep 10,616
