06-12-2015, 02:11 PM | #1 |
Rep 266
New (to me) E90 M3 - changing fluids, need input!
I'm picking up a lightly used (37k miles/60k km) 2008 E90 M3 6MT on the weekend from its second owner. I have the service records and everything seems to have been done as per the CBS recommendations (or better). But, I like to do more frequent servicing, partly because it's cheap maintenance and partly because I enjoy it!
That being said, I'm looking to do the following maintenance when I get the car using the listed parts/fluids: 6MT Tranny --> Change fluid (Redline D4 ATF or Motul Gear 300) and filter Brakes --> fluid flush with OEM fluid Oil & Filter --> Mobil 1 0W40 and Mann oil filter Differential fluid --> Castrol Syntrax SAF-XJ Air Filter --> Mahle Microfilters --> Mann PS Fluid --> CHF 11S (going to just do the turkey baster method) Looks like the spark plugs were changed at 28k miles/46k km so they should be good for a while. The differential fluid was also changed at 28k miles/46k km, but I think while I'm under there I may as well change it out as well. I've been doing a lot of reading on the various BMW/M3 boards and I think I've probably selected the commonly recommended fluids, etc. Any thoughts/additions/deletions to help give the car a "fresh" start? I'm also going to give it a full 12-18 hour detailing inside and out...
BMW M3 (G80)
Gone: 911 GTS, BMW 1M, E46 M3, X7 M50i, Porsche Cayenne GTS, X5M, M2CS, Cayman GT4 (981), Alfa Giulia QV, Carrera T, F80 M3 CS, Focus RS, M2 (OG), 14 E63S AMG wagon, M3 & M4 (F8X), X5 (F15 & E70), 335IS, VW Golf R (MK7), Audi SQ5, Cayman (987), M3 (E90), M5 MT (F10), A4 Avant (B8), S4 (B8), RS4 (B7), VW GTIs (MK2 to MK6) |
06-13-2015, 10:31 AM | #2 |
Rep 734
Congrats!
I did exactly the same thing when i first picked up my vehicle 6 months ago! Here is what i used: Transmission Fluid: Motul Gear 300 Brake Fuild: Motul RBF600 Brake Line: ECSTuning Front, Mid, and Rear stainless steal brake line set. (honestly you SS lines are really useless on the road... but its not exactly "expensive", so i swap them out anyways xD) Oil and Filter: Mobil 1 0W40 + Mann Filter (for the summer months now, i just changed the oil out again to a mix of Mobil 1 0W40 + 2.5 quarts of TWS 10w60) Differential Fluid: OEM fluid (the one with FM... costly as the M3 takes 1.5L, and it costs $50/500ml bottle...) Air Filter: Active Autowerks Green Filter Microfilters: Mann PS Fluid: CHF 11S turky baster way. Coolant: OEM + Motul MoCool (40:60 mix coolant/water) Good Luck and have fun!!!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
06-16-2015, 06:00 PM | #3 |
Rep 172
Congrats! Nice find on a low mileage 08.
I still need to do the power steering, diff and tranny fluids on mine. I'll be using the Redline on my 6 speed. |
06-19-2015, 03:25 PM | #4 |
Rep 947
OP, make sure to use the diff fluid with FM to avoid noises. And use Pentafrost NF by Pentosin for coolant.
06-19-2015, 04:06 PM | #5 |
Rep 266
Thanks for the input all. I received the records for the M3 and saw that the differential fluid was changed by BMW about 9,000 miles ago (14k km), so I'm going to leave that for now.
For the brake fluid I've seen the reference to LV (low viscosity) fluid. I had been planning on just ordering the OEM fluid because it's roughly the same price and also because it is available in smaller quantities so I won't have to throw a lot out if I don't use all of a bottle. But, there's no mention on the OEM bottle that I can see about being LV: http://www.ecstuning.com/BMW-E90-M3-...luid/ES193630/ Maybe it's assumed since its OEM and all BMWs need the LV fluid??
BMW M3 (G80)
06-19-2015, 07:40 PM | #6 |
Rep 5,506
I would do something similar and have on my own car.
The transmission filter for 6MT doesn't usually need to be replaced. You can take it out, clean it with some brake clean, dry it, replace the washer and put it back in. It is a metal screen filter that is supposed to be re-usable unless it's torn or filled with metal. I've changed transmission fluid twice and both times the filter was clean and fine.
Auto Detailing Enthusiast!
06-26-2015, 10:18 PM | #7 |
Rep 803
What I did and what I am planning to do....
6MT Tranny --> Currently debating which one to go with.
Brakes --> Pentosin Low viscosity. Just did the basic baster method (did not do bleed) Oil & Filter --> Still on OEM Differential fluid --> Royal Purple. Very happy with it. Air Filter --> Still on OEM. Vacuumed it out with high pressure vacuum at the car wash place. Looks extremely clean. PS Fluid --> Fairly soon. CHF 11S (going to do the turkey baster method)
Beware of Jeff Oliver the fraud at Highland Expedition Outfitters (aka HEO or HEOutfitters) located in Cosby TN.
07-13-2015, 03:16 PM | #8 |
Rep 266
Well, finally finished all of the below...
6MT Tranny --> Change fluid (Motul Gear 300) and filter Brakes --> changed with OEM fluid Oil & Filter --> Mobil 1 0W40 and Mann oil filter Air Filter --> Mahle PS Fluid --> CHF 11S O2 sensors --> both pre-cats with Bosch OEM equivalent Throttle Actuators --> Got a code that my passenger's side was going - rather than replacing the whole unit I went with replacement gears from alpina527 from M3cutters.co.uk. Worked perfectly! Everything went well. Thanks to all who contributed to the DIYs on this forum! Next on the list: - replace the exterior b-pillar and rear vertical window frames --> previous owner put "carbon fiber" film on top of them and they left a residue that is impossible to get off and it took some of the finish off - replace jack pads x 4 --> existing ones are all mangled from improper jacking - install OEM carbon mirror caps and OEM Type II Performance Carbon Spoiler - install Turner Motorsport's matte black grills - install F10 M5 illuminated shifter - 12 hour exterior detailing (interior done) --> decontamination, clay bar, cut, polish and seal
BMW M3 (G80)
07-13-2015, 05:42 PM | #9 | |
Rep 734
My E90 M3 threw the TBA code twice but have both gone away after a couple days. I am prepping to change both of them but those parts are super pricey... If i can get it fixed cheaper by rebuilding it it will definitely be awesome!!! Please let me know! You may shoot me a PM or you should really share your experience with that on another thread or something! We need to know this!!! Many Thanks!!
07-13-2015, 07:14 PM | #10 | |
Rep 266
The OP is the guy you want to contact (Ian, goes by "alpina527") - just send him a PM on the m3cutters.co.uk website and he'll get right back to you. The thread explains it pretty well and was enough to convince me. My thought is the longer you keep running the original gears after you've gotten the code the more risk you run of over-heating the circuit board in the TA. If the circuits go then you're looking at replacing the whole TA. The cost was just over $800 CA for replacement parts for both actuators with shipping & tax. Seeing as the cheapest parts I could find were about $900 US per actuator + exchange/tax/shipping, it worked out to less than half the price of replacing the TA (which would have the same, apparently faulty, gears).
BMW M3 (G80)
07-14-2015, 09:54 AM | #11 |
Rep 371
MarkFT, any difference in shifting with the Motul Gear Oil? Thinking of changing mine to Redline D4 ATF.
Also, why Mobil 1 0W40 instead of BMW 10W60?
07-14-2015, 10:03 AM | #12 | |
Rep 266
As for the Mobil 1 0W40 vs. BMW 10W60: since I'm in a colder climate (Canada) and I have no intention of tracking the car, I decided to go with the lower weight oil for cold start protection and hopefully better protection overall for the identified "tight" bearing clearances. I made my decision based on reading I've done online about possible benefits of switching to 0W40 (or similar) and the positive reports from those who've switched. I'll see how the car runs and go from there.
BMW M3 (G80)
07-14-2015, 03:24 PM | #13 | |
Rep 734
If DIY, how difficult was it? or is it super straight forward? Please let me know as i am only a novice mechanic and don't know if i should tackle this myself, or get an indy to assist. (thinking that even the Indy's probably havent dont a rebuild of the TBA. My indy only replaced new ones before). Many thanks!
07-14-2015, 03:55 PM | #14 | |
Rep 266
BMW M3 (G80)
07-20-2015, 10:57 AM | #15 | |
Rep 947
Also haven't you experience diff noises for not using the BMW with castrol SAF-XJ + FM? |
07-20-2015, 12:47 PM | #16 | |
Rep 803
As for differential fluid, I did some research and hw on this site before I used Royal Purple. People recommended, and I tried it. It works great, and has no grinding noise. |
07-23-2015, 11:11 AM | #18 |
Rep 734
Around 3 Quarts/Litres iirc
