06-08-2015, 11:54 PM | #1 |
Rep 558
Shell NiTRO Plus
Just noticed Shell's new V-Power NiTRO Plus at the gas station today.
It claims to "help prevent wear in critical engine parts. The new premium fuel also helps protect critical fuel system components from corrosion, destroys gunk left behind by lower quality premium gasoline; it then acts like a barrier to protect against gunk, wear and corrosion." The price jumped quite a bit as well. Curious if anyone else has seen this around. What do you think? Grade A marketing bullshit? Or will we see improvements to the wear and performance of our engines? |
06-08-2015, 11:56 PM | #2 |
Rep 11,891
price jumped? Doubt it's due to NiTro if they're rolling it out to all Shell stations
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
06-08-2015, 11:59 PM | #3 |
Rep 11,891
well considering Shell has a joint sponsorship deal with BMW M, and there's a M6 on the home page of Nitro, the fuel is probably optimized to add 1000 HP to your car and possible help out your rod bearings........
06-09-2015, 12:00 AM | #4 |
Rep 955
I filled up with this a year ago.
Made my idle bounce. Could have been the ECU adjusting. Who knows. I then filled up with this gas a week or so ago. No idle bounce, but noticed no difference really. I'm sure its great gas. For my M3, being in the EU market, its this or BP Ultimate only. |
06-09-2015, 12:02 AM | #5 | |
Rep 558
Definitely hope I'm pushing 1414 hp with glossy bearings |
06-09-2015, 12:05 AM | #6 |
Rep 712
More than likely a marketing campaign. BMW has recently partnered with Shell and calls it "the only fuel recommended for M series" blah blah. Probably going along with BMW's new Shell Helix oil partnership too.
http://www.shell.us/products-service...-gasoline.html |
06-09-2015, 12:05 AM | #7 | |
Rep 558
Thanks for the input. |
06-09-2015, 12:16 AM | #8 |
Rep 955
Yeah generally speaking, the quality of gas seams to be a bit higher in Europe. Perhaps this is how they try to justify charging nearly double what is charged in North America.
Another thing worth mentioning is where I am at currently anyways, there is usually only two choices as far as non-diesel goes. 95 EU RON (91 us octane) and 98 EU RON (94 us octane). I remember back in North America there was always 3 choices. Regular / Medium and High octane. Shell seams to be the only exception to the above where I am at. They have the 95 and 98, plus the nitro 100 you initially mentioned. |
06-09-2015, 12:50 AM | #9 |
Rep 536
Even though its my preferred gas, and the only gas i use... It's just gas mixed with some fuel cleaner?! With a name that will make you believe that your getting a boost in HP.
06-09-2015, 06:08 AM | #10 |
Rep 3,934
when i went to fill up at shell. the nitro is the only fuel that is available for 93 oct. I dont think there was a price jump. I cant see it being worse than the last formula. probably wont go out of my way to use it though.
06-09-2015, 09:08 AM | #13 |
Rep 364
Straight from Shell's website...
"Shell V-Power Nitro+ Unleaded is formulated with powerful cleaning agents designed to protect key fuel system components from gunk and to help remove some existing gunk as you drive. Shell V-Power Nitro+ Unleaded is also designed to form a protective film on metal surfaces helping prevent corrosion of critical fuel system components." The underlined statement concerns me. Given the lower bearing clearance on the S65, would an additional protective film reduce it even further and lead to increased wear? I don't know what the viscosity of the said film is, but it could either be much worse for rod bearings or it could be the holy grail. Edit: According to the Detroit Free Press, no independent verification has been done of these claims. But "theoretically" its possible. http://www.freep.com/story/money/car...nomy/28127105/ Last edited by digitalpersona; 06-09-2015 at 09:20 AM.. |
06-09-2015, 10:32 AM | #14 | |
Bad Lieutenant
233
Rep 3,517
Is your oil that contaminated with fuel?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
06-09-2015, 02:04 PM | #15 |
Rep 364
06-09-2015, 05:59 PM | #17 | |
Rep 11,891
y u no indulge my comment regarding 1000 HP and rod bearings?!
06-09-2015, 06:31 PM | #18 | |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
But I'll do most anything for a Scooby-snack... |
06-09-2015, 08:41 PM | #19 |
Rep 3,729
Drives: 2018 M2
So you're telling my I can have twin power turbo oil AND Nitro gas?!? Sign me up
06-10-2015, 08:34 AM | #21 |
Rep 3,729
Drives: 2018 M2
Shell should come out with "4WD" differential fluid to help my M3 during those snowy days
