05-22-2015, 04:42 PM | #1 |
Rep 41
Source for replacement Throttle Body Actuator Gears?
Well chums, it appears I may have a faulty actuator... got the "Christmas tree" of Check Control errors last night, which sometimes goes away on a restart.
I'm going to scan the car ASAP in case it's a faulty battery or something else (I believe battery in car is original), but assuming it is the actuator: - car had one replaced at 111,000 km. Not sure which. Still looking into that. - a gentleman in the UK makes replacement gears out of delrin and brass for lifetime longevity, see here: http://forums.m3cutters.co.uk/showthread.php?t=94742 I've sent him a message to find out if he has any sets left... and I figure I'll replace both sides while I've got the plenum off (and change the plugs while I have easy access). Canadian dealers want $1600 +taxes for a single actuator, compared to about $800 US stateside for one (insanity!), so if I can refurb them instead, it's a no-brainer to me. Read the DIY here: http://www.m3post.com/forums/showthread.php?t=735033 - pretty simple how-to, nothing crazy here. My ultimate question: Is there a source in North America for replacement or upgraded gears?? |
05-22-2015, 04:51 PM | #2 | |
Rep 955
One thing to keep in mind is I have read a few posts that had actuator issues, and it turns out the gears were just fine... But the electronics were not.
I may be wrong, but it may be prudent to have a look inside to make sure the gears are in fact the issue. Quote:
05-22-2015, 05:11 PM | #3 | |
Rep 41
Yes, I've read that electronics failures can happen, but are limited to about 10% of cases (also that the dealers will, in true modern BMW fashion, immediately lean towards claiming the electrics are the issue). I'll play the odds and assume the gears are wearing excessively... but in either case, if the codes thrown are showing actuator issues, I'll pull them, open them up and inspect. In any case, if I'm going to dig into this, I might as well future-proof them from gear wear failure... which again leads me to my original question above. |
05-22-2015, 05:17 PM | #4 | |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
So it is possible that even with new gears to still have a problem with the electronics part of the actuator. However, it appears that any S65 actuator with significant mileage on it (say, greater than 60k miles) will likely have visibly worn gear teeth in the most frequently used areas. All that said if you buy replacement gears and it doesn't fix the problem, you could re-sell the new gears on this forum I'd bet. |
05-22-2015, 05:21 PM | #5 |
Rep 11,891
you want OEM replacement or a manufactured upgraded part? OEM replacements can be found on various dealer online sites. There's a neat search feature that queries many dealers with 1 p/n search. let me know if you need this source.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
05-22-2015, 05:23 PM | #6 |
Woof!
352
Rep 1,323
Yep, but BMW doesn't sell parts to these actuators-- just the whole assembly. The aftermarket gears were developed by an outfit in the UK just for BMW throttle actuator failures. Haven't seen anyone producing them here in the US.
05-22-2015, 05:26 PM | #7 | |
Rep 41
I can get a complete actuator from all the usual online dealer sites at about $800. Used ones show up on eBay and such... but that just means I'll need to replace them again down the line - I'm hoping to 'rebuild' them to not have to deal with it again. |
05-22-2015, 05:28 PM | #8 |
Rep 11,891
yeah what a pain, it's almost as if we need to set aside $800 every 50k miles to replace these. Oh well, it'll be future-Flying Ace's problem! I just replaced it under my state's 7 year 70k miles emissions warranty.
05-22-2015, 05:29 PM | #9 | |
Rep 41
I just hate replacing a part with another that is very likely to fail in exactly the same way again, you know? |
05-22-2015, 07:56 PM | #11 |
Rep 530
I just replaced both my TA's from Tisher BMW I believe it was around $1500... Hopefully you can save some serious $$ and do the internal components in-house. Please keep us posted if you find the replacement parts. I'd like to give it a shot as well
05-22-2015, 08:30 PM | #12 |
Rep 1,260
The replacement gears by Alpina are 200 pounds per actuator (about $310). If you have errors at this point and your car is going into limp mode, your electronic may have failed due to the wear of the gears.
One member tried changing out the Mosfet on the electronic board but the replacement failed as well. They overheat. http://www.m3post.com/forums/showthread.php?t=1068709 IMO, best case scenario is to put in the replacement gears by Alpina into a new actuator unit. ... and that's not a guarantee that in time it will not fail.
05-22-2015, 08:47 PM | #13 | |
Rep 41
Time will tell when I get it apart, I guess. |
05-24-2015, 02:23 AM | #17 | |
Rep 41
I don't think anyone really knows for sure though. Guy in the UK still hasn't replied to me, so I'll likely end up finding a replacement unit here. Tried to scan the car today, but the 20pin to OBD2 adapter + GT1/INPA machine I was using wasn't working properly. |
05-24-2015, 06:05 AM | #18 |
Rep 955
On a side note, this TA issue is rampant. From what I can tell every vehicle is affected within the first 50-70K miles.
When I first took my vehicle that had 65000K KM in to have the spark plugs changed after purchasing used, the first thing that the mechanic told me when he popped the top off was "lookie here, looks like one of your TA's have been replaced". |
05-24-2015, 09:51 AM | #19 |
Rep 538
Yea considering the amount of fear spread about rod bearings... This issue seems to be more of a design flaw that will get each and every e9x m3 owner, yet it doesn't get the same sort of attention. I have 60k on my car now and I'm keeping an eye out for this.
A quick google search seemed to suggest Odometergears.com was planning on making a set of replacement gears at one point. Not sure if that went anywhere. Alpinas gears look really nice but to be honest at $310 per side that is really pricey. For a little more than double that you get a whole new actuator with a guarantee it will fix the problem (at least for another ~60k miles) |
05-24-2015, 10:00 AM | #20 | |
Rep 955
I agree that Alpinas gears are a bit pricy. I am sure they are an engineering marvel and all, but for two sets, its reaching close to the cost of a single OEM TA (I recall them being about 800USD a pop right?).
The route I would like to take is have one fail, order two sets of gears and fix both at the same time. But seeing as the price is a few hundred from a replacement TA, I may just be better off replacing the failed TA with an OEM one and seeing how much longer the other lasts. There is also the odd chance that I will end up ordering the gears, replacing them in both TAs only to find out that the electronics are fucked. This is all theoretical because as far as I know both my TA's are fine now... But at least the best route to take is not so clear with those prices. Quote:
05-25-2015, 02:34 PM | #21 |
Rep 41
So I finally scanned the car, and it's the actuator throwing the code, as I expected.
Alpinas in the UK still hasn't replied to me yet, so I'm going another route. I've found an auto electronics rebuilder who is getting back to me tomorrow (as it's Memorial Day in the USA). They rebuild the M5 ones, so they're just double-checking for me that they can do the M3's - seeing that the gears are identical in the M5 actuators, as is the electric motor, I'm going to cautiously assume that they're going to be able to help. I'll likely have to ship them my actuator to have them do it - and I'm probably going to have them check both of them. Hopefully by the time they go again, someone else will have engineered replacement gears to swap in. I'll keep everyone here informed as to price, turnaround time and results once it's all wrapped up - I've parked the car for now and am driving the E34 M5 instead. Tough life. |
05-25-2015, 03:52 PM | #22 |
Rep 91
For what it's worth, here is my recent journey with TVA. Apologize for the long post!
About 3 months ago, the first limp mode occurred in my '08 e90. I had 34700 miles on the clock and witnessed the tree of errors. After some searching around the forums, the errors did suggest TVA. Drove the car the very next day and errors remained, but limp mode gone. Over a few weeks the same pattern happened a couple more times. I opted to purchase the BT tool to check specific codes to do a little more analysis. The BT tool is great and was worth the $200 in my opinion for general diagnostics. The tool confirmed a bank 1 TVA failure. I tore down the car and removed the TVAs. Replaced plugs while I was in there. Noticed bank 1 had a very subtle catch about 2/3 through the arm sweep. Suspected gear problems and tore down. Could not see any noticeable gear wear. Checked electronics and there were no noticeable scars or burns from overheated components. I had stumbled on the M3cutters forum thread regarding the TVA and Alpina whom was making upgraded gears for them. After some discussion with Alpina, I decided to order 1 set of gears. He was very good to work with and very prompt. I knew there would be a chance the gears may not fix the problem but decided to go this route anyway. Gears arrived in about a week and install with the provided instructions was straight forward. Put the car back together, cleared codes, and test drove. Car behaved as normal. Next morning, limp mode reappeared. When I put the TVAs back in, I had swapped their positions as a check in case the errors appeared again. In deed, this was helpful. I pulled the codes and the error was now in Bank 2. The TVA that threw the original errors but now had replacement gears. At this point I ordered a new TVA. About another week later the new TVA showed up. Tore down the car and replaced the suspect TVA with the new one. That was 2 weeks ago. The car has been running error and limp mode free. I have driven it more than I usually do to build confidence the new TVA did correct the issue. I am very confident that it has. I would be happy to go into much more detail about any part of my journey, if it would be helpful. |
